Old 11-16-2011, 01:36 AM   #1
66farmer
66farmer's Avatar
Lokar shifter height
I need to order a lokar shifter for my 66, but I don't have the truck here to do my measureing. What height of shifter do you guy's have a picture would be great.
I will be using a reworked stock seat and the truck has a tall hump and I'm
6'5" I'm looking for just a comfortable reach.
Thanks for the help
66farmer is offline   Reply With Quote
Old 11-16-2011, 01:08 PM   #2
srsummers
Re: Lokar shifter height
I made my own out of round bar. I'll try to upload a pic but the knob sticks up over the dash. My is a Jeanie Shifter (which I think is very similar).
srsummers is offline   Reply With Quote
Old 11-16-2011, 01:15 PM   #3
jchav62
1962 C-10
jchav62's Avatar
We used a 16" floor mount lokar on the '65 with a high hump...
pics are after and before paint..
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-16-2011, 01:19 PM   #4
srsummers
Old 11-16-2011, 01:21 PM   #5
srsummers
Not the best pic but you get the idea. I had the 16" like jchav62 (still have it if you are interested). PM me if so.
Old 11-16-2011, 03:26 PM   #6
66farmer
66farmer's Avatar
JC
Why did you use a floor mount and not a trans mount.
Old 11-16-2011, 03:35 PM   #7
srsummers
It does mount to the trans, then you cut a hole in the floor.
Old 11-16-2011, 08:19 PM   #8
gimmy 64
23 in. lokar with low hump
gimmy 64 is offline   Reply With Quote
Old 11-16-2011, 09:37 PM   #9
Max1775
Max1775's Avatar
I used the 16 as well. Great height. I used a floor mount instead of a trans mount for a little flexibility in placement. Allowed me to place it left of center on the very edge of the hump. Looks just like Joe's above, just moved over a bit so I'll forgo adding another pic..
Max1775 is offline   Reply With Quote
Old 11-16-2011, 09:46 PM   #10
McCoyAZ
McCoyAZ's Avatar
I'm looking to buy a LOKAR floor shift for a powerglide if anybody has one for sale ?
The 16' looks good or a 20's.
McCoyAZ is offline   Reply With Quote
Old 11-16-2011, 10:19 PM   #11
jocko
jocko's Avatar
16.5" for T5 manual trans
Old 11-16-2011, 11:08 PM   #12
1stseries55
1stseries55's Avatar
32"
Jared
USMC 1st Battalion 8th Marines (95-99)
55 1st Series 3100 (on 98 sonoma frame)
65 GMC short bed fleetside big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=358493
1stseries55 is offline   Reply With Quote
Old 11-16-2011, 11:21 PM   #13
baggedbigblock
23" with after market adapter on a low hump, the adapter adds 2-3".
baggedbigblock is offline   Reply With Quote
Old 11-17-2011, 09:01 AM   #14
jason65
Registerd User
jason65's Avatar
23" Lokar in mine.
jason65 is offline   Reply With Quote
Old 11-17-2011, 10:58 AM   #15
jchav62
1962 C-10
jchav62's Avatar
Originally Posted by 66farmer View Post
JC
I figured I wouldn't have to cut a huge hole in the floor with a floor mount. Also, I heard that the trans mount shifters vibrate alot...
Joseph Chavez
Old 11-17-2011, 11:17 AM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
Here are shots of mine (high hump) when it had a 23” Lokar shifter mounted in the forward location. It fit through the original 4 speed hole after about ¼” of trimming.
And here it is later with a 16” Gennie shifter (also with an adjustable mount) after I pitched the Lokar:
FYI - I never got rid of the clutch pedal because I was always hopeful of going back to a manual 4 speed, which eventually happened.
Old 11-17-2011, 12:26 PM   #17
McCoyAZ
McCoyAZ's Avatar
Mark:
Why did you get rid of the Lokar shifter????
Old 11-17-2011, 02:29 PM   #18
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by McCoyAZ View Post
Mark:
There were several reasons.
1. I couldn’t change shift knobs which I often like to do (there were no adapters available back when I had my Lokar).
2. From day one the operating cable/rod inside the handle and the knob itself rattled which drove me nuts. Lokar subsequently released a revised knob with nylon around the edges. I installed one which was an improvement, but it didn’t help with the rattle in the handle.
3. Several times when not paying attention, I depressed the button in the knob with my thumb not centered on the button (too far forward). The sharp edge of the knob would quickly and painfully fold the thumb nail over backwards.
4. Living in North Idaho during the winter, temperatures frequently dropped well below freezing. When this happened, the grease in the handle would freeze solid immobilizing the shifter. This prevented moving the truck, and since this was my daily driver was more than just inconvenient. When the weather warmed up enough, I ran two full cans of WD40 down the handle and rinsed out all the grease. From this time on I could shift regardless of temperature, however the rattle became insanely loud challenging my mental faculties. I finally just couldn’t stand the rattle anymore and pulled the shifter. I gave it away as I didn’t feel good about selling it to anyone else.
Previously I had a Gennie Shifter in my 46 Ford. I loved that shifter but at the time I built the truck Gennie didn’t offer an adjustable mount. By the time I got rid of the Lokar, Gennie had released a similar style adjustable mount, so it was a no brainer for me.
Old 11-17-2011, 04:12 PM   #19
chad64chevy
chad64chevy's Avatar
max1775- i would like to see your shifter! i have a low hump and it had a three speed on the floor with the hole in the side of the trans hump! and what lokar shifter did you use?? sorry just read you used the floor shift!!
chad64chevy is offline   Reply With Quote
Old 11-17-2011, 07:11 PM   #20
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Lokar shifter height
16'' Lokar TH350 Auto Trans Shifter Tail-Shaft Mount
Jegs
http://www.jegs.com/webapp/wcs/store...sion+Shifters+
Google: 67-72chevytrucks.com
http://www.google.com/custom?hl=en&s...hevytrucks.com
Lokar
http://www.lokar.com/product-pgs/shi...hifter-pn.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
