11-16-2011, 04:02 PM | #1 |
Trying to locate factory steel wheels w/4 bumps on front for disc brake/ whubcap
Anybody know where to locate some of the factory steel poverty rims that have the bumps on the front to hold the dogdish hubcaps? They'll have 4 holes in the rim. I need some to do a disc brake conversion on a 63 and the rims were stock chevy/gmc from 74-up.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-16-2011, 09:53 PM | #2 |
Re: Trying to locate factory steel wheels w/4 bumps on front for disc brake/ whubcap
Any C10 or G10 van in the junkyard.
11-16-2011, 10:20 PM | #3 | |
The 5-lugs can be found under many 'plain' 71-87 GM trucks or suburbans that had factory full wheel hubcaps. The 6-lug models were the 'cheap' wheels on the 73-87 4wd's (blazers, burbs, & trucks). The 6-lug wheels are harder to find.
11-17-2011, 09:36 AM | #4 |
Looking for the 6 lug. Have two....but need at least 1 for a spare and would like 3 total. I have been through every yard within 45 min off here that I know of and can't locate any. Should be a common wheel.
11-17-2011, 01:55 PM | #5 |
Common then, but hard to find now.
11-17-2011, 03:20 PM | #6 |
Yeah...seems so. But like most of the stuff we want...just keep on looking. Its out there somewhere
