Exhaust pipe size?
Stock Exhaust O.D. on a 1984 Chevy C10 stepside? 2.5 inch?
Thanks |
Re: Exhaust pipe size?
Yes I do believe that is correct. My 82 C10 had 2.5"...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
k thanks.
its double wall tubing from factory so inside diameter is close to 2 1/4
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Cruzzzn' Vet
3" single exhaust on mine
mine ended up with 3" duals...
Stock iron manifolds have 2" fittings, so they usually use that size pipe for the whole system if it has full duals. If it runs into a cross-over and a single pipe, I'm not sure how much bigger that pipe is. Most of the aftermarket duals from Hooker and other companies use 2 1/4" pipe, since it will handle engines up to about 325-350 hp.
Some folks (and manufacturers) add larger tips on the pipes to make it look like bigger pipe. My Mustang has 2 1/2" dual pipes, but you can get up to 4" factory tips to put on the mufflers. Bruce |
Mine's aftermarket, built by Ken's in Ft Collins for me via my requirements.
2.5" duals with "H" pipe, straight out the back. Hookers provide the flow. Perfect. Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
