Old 11-16-2011, 07:35 PM   #1
Scottsdale Doc
Plug wires & plugs
Today I pulled a plug wire off my 85 scottsdale ( 350 Eng) and it made no difference in the running of it. I continued removing one by one and 4 of the 8 made no difference in the way the engine run. I am confused.
The dist is electronic and is putting out based on the spark from the wire to the cap. Has anyone had this happen to them & if so what was the fix.
The engine does not run that bad but I am confused as to why removal of a plug wire does not make a difference when it is removed.
Scottsdale Doc is offline   Reply With Quote
Old 11-17-2011, 03:31 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Plug wires & plugs
you ran your truck on four cylinders?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-17-2011, 03:39 AM   #3
juiceman650
juiceman650's Avatar
I accidently wired 2 of my cylinders out of the firing order and noticed that it would idle fine, but when I'd drive it (put the engine under load) it'd start to backfire and miss.
1975 Chevy Cheyenne w/ v8 350 and TH350
Siverado interior
Fleetside bed
aka "The Beast" aka "Cheyerado"
juiceman650 is offline   Reply With Quote
Old 11-17-2011, 06:10 AM   #4
lurch115
lurch115's Avatar
had a friend of mine help me do a tuneup once and he accidentally switched the center 2 plug wires on the passanger side of the motor around. probably never would have caught it but everyonce in a while sitting at a light idling it would let out a light pop and die.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 11-17-2011, 01:57 PM   #5
Tucson38
I'm sure you'd notice when you put the engine under load. I'm surprised you could pull off 4 plug wires and it ran for you.
Tucson38 is offline   Reply With Quote
Old 11-17-2011, 02:43 PM   #6
Scottsdale Doc
Sorry for confusion, I pulled them off one at a time and put them back.
I've taken truck into pep-boys for diagnostic test.
