11-16-2011, 08:18 PM | #1 |
Correct spacers needed????
Im looking to put some rims on my 86 silverado (5x5). Here are the specs.
Bolt Pattern: 5x120 Center Bore: 67 Hardware:14x1.50 Lug Offset: Front: 30-40mm Rear: 30-45mm Can anyone recomend the correct spacers and possibly a brand? Thanks |
11-16-2011, 08:33 PM | #2 |
Re: Correct spacers needed????
5x120mm wheels would not work...they need to be 5x127mm=5x5
Or are you asking about adpters(to change bolt pattern) Or spacers to move them out some?
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
11-16-2011, 08:34 PM | #3 |
67-72 parts collector,…
Offset means nothing unless you know the rim width.
11-16-2011, 08:36 PM | #4 |
Here's a good chart:
11-16-2011, 08:46 PM | #5 |
Sorry I should have done a better job wording it. I need adapters with the correct back spacing.
Posted via Mobile Device |
11-16-2011, 08:50 PM | #6 | |
1) what size wheels? 2) exact offset? 30-40 mm is a range. It's either 30 mm or 40 mm. Not both. 3)Is your truck stock height or lowered? How low?
11-16-2011, 08:54 PM | #7 | |
1" wide. 1.5" wide. 2" wide. 2.5" wide.
11-16-2011, 09:42 PM | #8 |
Ok guys sorry about that been a long day and I wasnt paying attention to the original specs posted. Here is what I have:
5x5 lug pattern 2.5" drop upfront 2 leaf springs removed Rims I want to put on: 5x120mm pattern 20 x 8" / (front) P245/45ZR20 (front) +35mm offset 20 x 9" / (rear) P275/40ZR20 (rear) +40 offset |
11-17-2011, 03:08 PM | #9 |
Anyone?
11-17-2011, 06:32 PM | #10 |
20 x 8" / (front) P245/45ZR20 (front) +35mm offset equals an approximate 5-7/8" Backspace.
20 x 9" / (rear) P275/40ZR20 (rear) +40 offset equal an approximate 7" back space. That's alot of backspacing on wheels for these old trucks. I would think a 1" adapter for the front wheels and a 2" adapter for the rear wheels. The best way to measure would be to "mock up" the wheels and measure how much they need to move outward.
11-18-2011, 12:43 PM | #11 |
Great thanks for the info. Will try to figure it out this weekend.
