ok i have a Heidts mustang II crossmenber and it the insctruction its says to install it at 20 7/8 from the center of the bolts of the springs .
But i dont have my fenders to check if its in the center of the fenders so did you guys instal it at 20 7/8 (stock) or you move the crossmenber ? thanks |
#2 | |
Re: Tci / Heidts crossmenber
My truck is a 1957 chevy
Sorry to ask again but i just whant to know what you guys did ?
i am ready to weld ![]() |
20-7/8 from the front shackle hole on a 55/59 according to the instructions on the web site. links for All of the instruction manuals for Heidts products are here http://www.heidts.com/instruction_manuals.html
Welder's Series instructions while intended for their U weld it universal crossmember are good for any MII install. http://www.welderseries.com/instruct...itsinstall.htm From Classic Trucks step by step with photos. http://www.classictrucks.com/tech/05...l/viewall.html Last edited by mr48chev; 11-18-2011 at 07:49 PM. |
#6 | |
48/53 are 18-1/8 or 18-1/4 depending on the vendor. Heidts is 20-7/8 for Task Force trucks 55/59. DG Racing is working on a Task force truck. I think we have several with that front end on their Task Force trucks so maybe one of them will chime in and bring out a side view photo. |
eliminating double post.
Thank you Mr 48 chev for your links, very nice
![]() but i was just hoping to have a confirmation from guys that did weld it to 20 7/8 inch . i just spot weld it , and before i weld it completly i will instal the fenders next week end to make sure its centered . |
That sounds like the best plan. Some guys do set them ahead on those rigs so that the wheel centers in the wheel well better. They may have taken that into consideration with their measurements.
![]() Join Date: Jul 2010
Looking at the pict, you've got it right. We use the leading edge of the factory brake line hole. This is 3/8" ahead of the OE centerline, and will put the wheel dead center.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
Thanks for the Info
![]() i will weld it this week end ![]() |
