11-17-2011, 12:39 PM | #1 |
700r4 ?
I just installed a 700R4 and haven't hooked up the lockup solenoid. Can I still drive it like that? I'm only going to be driving it in town.
11-17-2011, 02:03 PM | #2 |
Re: 700r4 ?
As long as the converter doesn't slip excessively in high gear, it should be no problem at all.
11-17-2011, 02:25 PM | #3 |
meowMEOWmeowMEOW
Re: 700r4 ?
grab a 2 position toggle switch and wire it in temporarily; let me get mine to lockup on the hwy, at least while I figured the other stuff out with the brake switch.
If you need the part number for a 4 post brake switch for lockup I have that as well.
11-17-2011, 04:21 PM | #4 |
Re: 700r4 ?
i test drove it shifted good three times could hardly feel it and didn't feel no slipping
11-17-2011, 04:31 PM | #5 |
Registerd User
Re: 700r4 ?
I been driving mine for 2 years with out the lock up hooked up. No problems so far.
11-17-2011, 06:01 PM | #6 |
Re: 700r4 ?
You acually want to feel the shift. The tranny I had in my 79 4x4 would chirp the rear tires sometimes. Man that thing shifter hard. I think I will take the corvette style servo out and see if that calms it down a bit. This is a 700R4 I am talking about. I was using the truck for alot of hauling and stuff so I put a reprograming kit in it along with the Corvette Style servo.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
11-18-2011, 01:28 AM | #7 |
60-66 Nut
Re: 700r4 ?
I hope you setup the TV cable correctly. That is more important than the lockup. However the lockup is also important, but that not functioning won't burn up your trans in a short time, like a improperly setup TV cable.
11-18-2011, 01:55 AM | #8 |
Re: 700r4 ?
Are you running a carb? Wanna buy my lockup kit? lol
http://67-72chevytrucks.com/vboard/s...d.php?t=493968
IBEW Electrician-Nick 1985 C20 Silverado 1965 C-10 short fleet 1961 c-10 Apache short fleet 2005 Chevy Suburban LT 2012 Hyundai Sonata |
11-18-2011, 02:41 AM | #9 |
Re: 700r4 ?
Concur with CaptFab - and part of the process should usually be a line pressure check I believe.
Here's a good thread on tv cable adjustment: http://67-72chevytrucks.com/vboard/s...49#post4038749 Some great tv cable background info: http://www.tvmadeez.com/article/index.php Lockup Wiring if you'd like to go beyond just a toggle: http://www.bowtieoverdrives.com/cata...BCAT&CATID=OA1 Most Excellent install kit (not that you need it, but is it does show you what you "needed" at install, the gauges to check pressure, etc - and you may have it all laying around at home already... http://www.bowtieoverdrives.com/cata...php?ITEMID=572 Generally speaking, the "Bowtie Overdrives" site has a great deal of good info on 700R4s, install, and parts. Hope that helps. Again, all the fancy stuff may not be necessary, but completely agree with Capt, the TV cable must be adjusted correctly or you'll burn er up in no time. |
11-18-2011, 11:31 AM | #10 |
1962 C-10
Re: 700r4 ?
I also agree... TV adjustment is #1.
On the 700r4 we put in the '65, we bypassed the lockup switch in the trans. No problems there....
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
