Old 11-17-2011, 12:53 PM   #1
bpeters5814
bpeters5814's Avatar
'80 K20 Engine Question
Hey all, I'm usually on the '88-'98 forum, but I've been looking for a 3/4 ton 4x4 square body for a long time. There's one coming up on an auction in about a month. The listing says "gas engine". I called the lady selling it, and she has no idea if it's a 350 or a 400. Is there an easy way to tell? And if it's a 400, what should I watch out for? Not too familiar with those. Thanks in advance.
bpeters5814 is offline   Reply With Quote
Old 11-17-2011, 02:49 PM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: '80 K20 Engine Question
Just a little tip, 400's are opposite 350's when it comes to mains. The 2 bolt main 400's are stronger than a 4 bolt. I don't know anything about identifying one from the outside though...
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 11-17-2011, 08:04 PM   #3
Your41Plague12
Your41Plague12's Avatar
You'll have to pull a head off to verify it, unless you have a book of casting numbers. The heads have steam holes drilled in them, they're a totally different beast internally than a 350.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-18-2011, 12:31 AM   #4
bpeters5814
Alright, thanks guys. If it goes for the right price, I'll buy it regardless. I was just wondering.
Old 11-18-2011, 02:07 AM   #5
Your41Plague12
Either a 350 or a 400 will be a good engine. You mainly have to watch people swapping heads on a 400. They'll overheat easily if 350 heads are put on a 400 because of the lack of steam holes.
Steve
Old 11-18-2011, 08:48 AM   #6
Keith Seymore
Keith Seymore's Avatar
Also - if it's the original engine (if she can tell you it's never been changed) then it would be a 350.
A 400 cubic inch engine was not available in an 80 K20 Suburban from the factory.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-18-2011, 08:36 PM   #7
tater502
If its a 400 it will have a groove in the balancer. I dont know if they are all like that, but all the 400 balancers I've seen are.
tater502 is offline   Reply With Quote
Old 11-18-2011, 09:36 PM   #8
rayfinseats
Some 400's have 3 softplugs on the sides vs. two.
rayfinseats is offline   Reply With Quote
Old 11-19-2011, 07:35 AM   #9
hatzie
Moderator
hatzie's Avatar
If it's the original V8 engine read the third VIN letter.
R 400
M or L 350
G 305
S 454
Old 11-19-2011, 09:42 AM   #10
bpeters5814
This is what they have down for the VIN: CKX24AJ137689
So... is that right? I tried using a VIN decoder and it didn't recognize it. I'm going to go look at it hopefully this week or the next, so I'll verify it.
Thanks all!
