Old 11-17-2011, 01:47 PM   #1
Tucson38
Heater core replacement experience.
'85 GMC 3/4 4wd - Attempted a heater core swap for the first time. Took about 6 hours but it went well. I was concerned about the thru-firewall bolts accessibility. Room was a little tight under the A/C unit but not as bad as I anticipated. Found a couple of broken nylon fittings on the controls but couldn't find replacements online so I had to fab a couple of units.
Looked all over online for a copper heater core, finally found one at O'Reilly's for $28 surprisingly. Tried one from NAPA but it was all aluminum.
Next up: pulling the dash to replace the lamps and a new fuel gauge. New stereo unit should be delivered today. After that new seat skins, floor carpeting and seat belts. Maintenance catch-up time.
Tucson38 is offline   Reply With Quote
Old 11-17-2011, 02:30 PM   #2
Low87
been here longer than Liz
Low87's Avatar
Re: Heater core replacement experience.
I recently did my first one as well. Now that I've seen it, next one should go well. Definitely not a fun job though.
Try LEDs for your dash lamps, I did this recently also and like it a lot better than straight replacements. I used superbrightleds.com.
Have fun!
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 11-18-2011, 11:27 AM   #3
Tucson38
LED's - good idea. Never thought of that. I checked out the website but confused about which ones I need. What did you wind up using? I assume the 4 led ones would be the best choice.
