Old 11-17-2011, 09:52 PM   #1
cstm68
cstm68's Avatar
piston slap?
anyone eles get piston slap on cold starts? my 01 5.3 gets it for about 30 seconds on cold mornings, is there anything i can do to fix this? is it hurting anything?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 11-17-2011, 10:48 PM   #2
clinebarger
Re: piston slap?
Very common on all LS based engines, I think the 5.7L & 6.0L are the loudest.
I had a 5.7 aluminum LS1 that sounded like it was going to come apart on cold starts, But never did even with my lead foot & a supercharger. So dont worry about it.
clinebarger is offline   Reply With Quote
Old 11-17-2011, 10:59 PM   #3
Slowtruk
Slowtruk's Avatar
Re: piston slap?
He's right, very common. But, its virtually impossible to blow an LS engine up. I have a lot of experience with too many of these things. Great engines no matter what the sound.
IBEW Electrician-Nick
1985 C20 Silverado
1965 C-10 short fleet
1961 c-10 Apache short fleet
2005 Chevy Suburban LT
2012 Hyundai Sonata
Slowtruk is offline   Reply With Quote
Old 11-18-2011, 12:14 AM   #4
mixermike
mixermike's Avatar
Re: piston slap?
just turn the radio up a little and drive.no worries
mixermike is offline   Reply With Quote
Old 11-18-2011, 01:18 AM   #5
Slowtruk
Slowtruk's Avatar
Re: piston slap?
Most of the piston slap should go away once the engine warms up
1985 C20 Silverado
2012 Hyundai Sonata
Old 11-18-2011, 01:21 AM   #6
383longhorn
383longhorn's Avatar
Re: piston slap?
i like mixermikes solution to the prob
Josh
1970 custom camper 20 longhorn
1970 ford f250 highboy
383longhorn is offline   Reply With Quote
Old 11-18-2011, 01:36 AM   #7
cstm68
cstm68's Avatar
Re: piston slap?
ok thanx i wont worry about it, it only does it on cold mornings for about 30 seconds
Old 11-18-2011, 01:50 AM   #8
Slowtruk
Slowtruk's Avatar
Re: piston slap?
yep some say its because the aluminum pistons are slightly too small when cold for the cylinders, but the noise decreases when the pistons get warm and expand
1985 C20 Silverado
2012 Hyundai Sonata
Old 11-18-2011, 12:29 PM   #9
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: piston slap?
GM's "fix" for this when the Gen IV stuff came out in '05 was moving to bushed rods with floating pins instead of the pressed pins that the gen III motors had. My '01 5.3 slaps pretty good when it's cold.....140k miles going strong!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-18-2011, 01:45 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
Re: piston slap?
Mine has almost 140K as well. I hate this time of year (winter) because it can be pretty loud, but goes away like everyone else said. In the summer it's usually fairly quiet and short, or doesn't do it at all. Mine never really started to be noticable until it got up to around 80K. Doesn't burn oil and still gets the same fuel mileage it did when I first got it, so I guess it should be fine.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-18-2011, 01:50 PM   #11
Slowtruk
Slowtruk's Avatar
Re: piston slap?
I have a 2000 5.3 extended cab with 230,000 miles....still running like a champ. Ive had a few others too
1985 C20 Silverado
2012 Hyundai Sonata
Old 11-19-2011, 09:47 AM   #12
Boog
laying low
Boog's Avatar
Re: piston slap?
I've seen a bulletin from GM some time in the past about the issue. It's common on these engines. I've heard some folks really get down on GM for producing something like this.
As much as these vehicles cost you would think they wouldn't knock or peck with low miles.
Does anyone happen to have a copy of that tsb from GM?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-19-2011, 10:01 AM   #13
truckdude239
truckdude239's Avatar
Re: piston slap?
http://www.pistonslap.com/tsb/010601028.pdf
Info - Engine Knock on Cold Start #01-06-01-028 Engine Knock on Cold Start 1999-2002 Chevrolet and GMC C/K Pickup and Utility Models 2002 Cadillac Escalade (2WD) with 4.8L, 5.3L or 6.0L Engine (VINs V,T,U - RPOs LR4, LM7, LQ4) Some of the above vehicles may exhibit an engine knock noise that begins in the first 19,000-24,000 km (12,000-15,000 mi) of use The knock noise is most often noticed during initial start-up and typically disappears within the first 5-30 seconds (may last longer in extreme cold temperatures). The noise is usually more noticeable on the initial start-up when the temperature is below 10 degrees C (50 degrees F) and may be more pronounced on the first cold start following a long trip. This noise may be caused by an interaction between carbon that has formed on the piston, the piston motion and the cylinder wall. GM Powertrain Engineering, and an analysis of engines with this condition, has confirmed that the noise is not detrimental to the performance, reliability or durability of the engine. THIS NOISE DOES NOT HAVE ANY EFFECT ON THE LONGEVITY OF ANY OF THE ENGINE COMPONENTS. Important At this time, attempts to repair this condition by replacing the engine assembly or pistons is not recommended. Please share the information found in this bulletin with customers who inquire about this condition. In the event they have additional questions orconcerns, please advise your Area Service Manager. www.pistonslap
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-19-2011, 08:54 PM   #14
Boog
laying low
Boog's Avatar
Re: piston slap?
That'd be the one. Thanks.
Boog
primer is finer
