Door wont lock
My 62 gmc doesn't have a lock handle on the driver side, just the passenger side. I can't lock my driver door, with window down I lock it from the inside, then push the button and it opens. Is there something missing? I've also tried to switch the buttons, but the rod attached to the passengers side button is longer. If I buy a lock button with the rod longer than what it has now, can i cut it to size and be fine and will it lock? Hope this makes sense.
Re: Door wont lock
So, let me get this right...you dont have an external lock on the driver door but do on the passenger door?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Door wont lock
Err...have a lock on the driver, but DONT on the passenger side?
Re: Door wont lock
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Door wont lock
Passenger side keyed door locks were an option. Could someone have tried to fix the door handles and mixed the door buttons from side to side.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Re: Door wont lock
Thats what I was thinking. These trucks came with a driver side door lock, the passenger side was an option (bout $2-3) that could be ordered. I would suggest swapping the door handles on the doors.
Re: Door wont lock
Handles are left and right! It's the internals.
Re: Door wont lock
Thats what I meant...brain and fingers aren't typing what im thinking...sorry
Re: Door wont lock
I've tried that and the internals are the buttons attached to a rod. The rod on the pass. side handle with the lock button is longer then the one on the drivers side. So when I switched them the driver door wouldn't even latch, you could just pull the door open. I think I'm going to get a lock button and cut down the rod to the dummy button that i have now and see if it latch's.
Re: Door wont lock
Also as mentioned on first post, when i lock the driver door i can push the button and it opens. Is there a lever or something missing inside the door so it can lock? If so, that i can do so i can just lock up my truck.
Re: Door wont lock
I've never locked my truck and the key is always in the ignition.
In those years did you not simply lock the button from moving in the exterior door handle? If you lock the interior handle, the key does not release the inside handle, it simply allows the button on the exterior door handle to travel inwards, which releases the latch mechanism.
Re: Door wont lock
So It might work then. I'll have to get a used button and try. Thanks
It must be nice, that you can leave the doors unlocked with keys in the ignition and not worry. I in the other hand live in California, nuff said. |
#13 |
Re: Door wont lock
Yeah but on your way to the grocery store you can buy milk and rear seats for a 63-66 GMC suburban. Used to travel to California when I drove truck. Could always find something to buy. Now stuck in farmland Canada where getting an accessory in your plain Jane farm truck was blasphemy! Just showin off eh!
#14 |
Re: Door wont lock
Ok so I got a lock button from the junk yard today. I installed it and it would not latch. The lock button rod is 3/8" longer, so i cut it and worked. Now I just have to get it re-keyed. Then I'll have one key for the two doors, glove and ignition.
#15 | |
Re: Door wont lock
#16 | |
![]() Join Date: Sep 2003
Re: Door wont lock
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
#17 | |
Senior Enthusiast
Re: Door wont lock
On my 1960 GMC the inside and outside locking mechanisms are independent of each other. Actually locking the door latch (in the door jamb) can only be accomplished by using the inside door handle. Locking the outside button with a key merely prevents the handle button from being depressed. It doesn’t actually move the latch into the locked position. If the door cannot be locked from the inside the linkage between the handle and the latch is out of adjustment. And if the inside handle is in the locked position, the outside door button will be unable to open the door, regardless of key position. BTW- I also have matching outside door lock buttons that are keyed same as the ignition and glove box, and it's very convenient. |
#18 |
Re: Door wont lock
Thanks markeb01 I thought something was wrong with the linkage. I'll have to look for a diagram of the door locking mechanism, cause I'm not sure what I'm looking for.
Also do you think by locking the button with the key would work, you wouldn't be able to depress the button so you wouldn't be able to open the door...right.? |
#19 | |
Senior Enthusiast
Re: Door wont lock
Perhaps these details from the 1960 Shop Manual will be of some help: ![]() ![]() Last edited by markeb01; 11-20-2011 at 04:11 AM. |
#20 |
Re: Door wont lock
Thanks markeb01
#21 |
Re: Door wont lock
Nice timing on this thread. I had a spare door with lock that I had rekeyed a couple of weeks ago, but hadn't installed. I tackled it today after reading this thread. Went in without a hitch. Andyboy, I didn't need to cut it either, but both truck and extra lock were from 64-66. They both stuck out the same 1 1/8". Did you cross a lock from a later truck to an earlier?
Regards, Steve New Orleans PS Markeb01 thanks for a nice write up. |
#22 |
Re: Door wont lock
Well slorio, I'm not sure if there from 64-66. but i did get the lock button from a 1960 and as the 1960 shop manual says, the lock button is on the right side. So maybe someone put in a later one on the left side. I'm glad your worked out great.
The thing that gets me is the one on my pass. side door works fine. So I'm thinking the locking mechanism on my driver door is bent forward. Thanks again for the photos of the manual, Markeb01. |
#23 |
Re: Door wont lock
One of my buddies has a 64 long bed fleet. He drove up at his shop one morning to find his driver's door handle lying in the parking lot - (with no truck attached to it). His truck was found (thankfully) a few miles away (out of gas) with the radio and some of his tools stolen. The truck was locked, but the thief pried the WHOLE HANDLE OFF the driver's door, then poked his finger inside the hole and hit the striker and with a couple of twists of wires, away he went with the truck. So much for "LOCKING" the doors. Dan decided to just shave the handles off and leave the truck smoothed out with remote poppers, so he won't have to worry about it happening again.
Sam |
#24 |
Re: Door wont lock
Sam, sorry to hear about your friends truck. That really sucks thankfully it ran out of gas. I have to run mine like that until I figure out whats wrong with the mechanism inside the door, but thanks for the heads up.
