Old 11-19-2011, 02:55 AM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Lost highbeam switch: 87 Signal Lever Question
Hi all;
in the process of taking my steering column apart to replace key cylinder I lost the spring for the high beam switch which is actually the turn lever when you pull it forwards.
Right now it doesn't click back automatically to its set position, it just stays losely where it gets pulled or pushed to. Pictures of my style of lever are attached.
Does anyone have any links or pictures of what that spring looked like or can show how the turn signal level should be put back together so I can see if I just forgot to hook something up??
Thanks!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 11-19-2011, 03:22 AM   #2
Greenlee
Greenlee's Avatar
Re: Lost highbeam switch: 87 Signal Lever Question
There is a plastic gizmo that has to be positioned just right to activate the high beams. It helps to use a little grease to hold it in place. There are great pics and instructions here:
http://www.diyfiero.com/dropspot/Jaz...ck_Rebuild.pdf
Greenlee is offline   Reply With Quote
Old 11-22-2011, 01:51 AM   #3
Gordonr1973
Home Built '87
Thanks for that write up.
Took a while to get it right but it absolutely worked.
Gordon
Old 11-22-2011, 03:06 PM   #4
Weasel Diesel
The Gizmo got caught in the Whachamadingit, and the piston got hung up in the driveshaft, and caused the carburetor to rust out...
Weasel Diesel is offline   Reply With Quote
