Old 11-19-2011, 05:06 AM   #1
ZZ4Blazer
Intermediate shaft removal
Been trying to get the intermediate shaft out of my truck as its hitting the UCA with my porterbuilt crossmember. Need to get the suspension assembled so I can get the truck able to move around.
Searched, but was kina vague and left with me with more questions.
Someone said at the 67 and 68 steering shafts were one complete peice from the steering box all the way up to the steering wheel.
Is that true? Im working on a 68, and have a 67 sitting right next to it. Yet, the 67 has a regular bell kinda connection at the steering shaft with a bolt running through it like most any other GM trucks Ive worked on from various years....
Although, I started thinking about it and supposedly the PO added power steering to the 67.
The 68 looks completely different. For the record, Im trying to remove the intermediate shaft from a 68 truck, automatic column and factory power steering.
ZZ4Blazer is offline   Reply With Quote
Old 11-20-2011, 04:29 PM   #2
ZZ4Blazer
Re: Intermediate shaft removal
anyone?
Old 11-20-2011, 08:56 PM   #3
JimKshortstep4x4
Does your steering column/extension look like this at the lower end of the steering column? If it does then the extension can be removed by disconnecting the rag joint at the steering box and then removing the clamp bolt on the connection of the extension to the steering shaft. Usually the clamp has to be tapped off before the part can be pulled off of the splines. I have not tried removing an extension with the column in the truck but there might be enough room.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-20-2011, 09:10 PM   #4
ZZ4Blazer
No it doesn't. That's how my 67 looks. Not my 68 that I'm trying to get off
Old 11-20-2011, 09:20 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You have to remove your steering column. Someone changed the column on your 67 because it was the same as your 68 from the factory. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-20-2011, 09:35 PM   #6
ZZ4Blazer
So the intermediate isn't removeable? That's gonna cause a problem with the steering linkage for my rack n pinion
Old 11-21-2011, 03:25 AM   #7
ZZ4Blazer
This is what mine looks like.
Old 11-21-2011, 04:44 AM   #8
project 67 sub
project 67 sub's Avatar
you could always cut it....
project 67 sub is offline   Reply With Quote
