Old 11-19-2011, 01:30 PM   #1
RustyJunkMan
79-82 Small Block I. D.
HI: I have a Chev Small block and would like to know if it is a 305?, 327?, or a 350?. Does anyone know an easy way to tell. Any help will be appricated,
Thanks, RustyJunkMan.
RustyJunkMan is offline   Reply With Quote
Old 11-20-2011, 10:36 PM   #2
russgt
russgt's Avatar
Re: 79-82 Small Block I. D.
79-82 is not a 327. Visually, the dampers are different sizes on the 305 vs the 350
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 11-21-2011, 09:22 AM   #3
RustyJunkMan
Old 11-22-2011, 07:07 AM   #4
lurch115
lurch115's Avatar
there is a casting number either on the driverside of the engine block just ahead of the transmission bellhousing that you can look up online, or there is also a 3 digit number cast into either side of the engine block by the motor mounts.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 11-22-2011, 11:41 AM   #5
406 Q-ship
406 Q-ship's Avatar
Get the engine code off the engine pad (right in front of the right cylinder). It will be a three letter code that will tell you everything you need to know.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 11-22-2011, 02:54 PM   #6
RustyJunkMan
Thanks Everyone
RusryJunkMan
