Old 11-19-2011, 01:37 PM   #1
drhchevy
86 Sierra Classic No Headlights
Hi all, I need some advice. My 86 Sierra has park lights, tailights, signals and brake lights but no headlights, high or low. I changed the switch with a used one, nothing. There is power going to the headlight switch and all the fusible links from the starter are showing power at the fuseblock or firewall. The 5 amp accessory fuse is good and has power going to it on both sides of the fuse. I also disconnected the lighting harness from the fuseblock and when I jump it it from the battery, the light will come on. I also cleaned all the grounds that I saw related to the lights. I am at a total loss here and traced the Chilton schematics to no avail as well. Any help would be much appreciated. Thank you very much
drhchevy is offline   Reply With Quote
Old 11-19-2011, 04:05 PM   #2
C-10 simplex
Re: 86 Sierra Classic No Headlights
EDIT: i just read the post a little more carefully. My solution is invalid.
C-10 simplex is offline   Reply With Quote
Old 11-19-2011, 04:27 PM   #3
ont_guy_38
ont_guy_38's Avatar
Not sure where the dimmer switch is wired in but I know with the ones on the floor if that was bad your headlights did not work
ont_guy_38 is offline   Reply With Quote
Old 11-20-2011, 09:06 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
86 wouldn't be on the floor
i'd wonder bout the used switch
remove it and use a test wire
between the red and the yellow
only for a test,this will run the headlights,if the wires are good past the switch
if not check the orange
Do you have power at the orange and red?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
