Old 11-19-2011, 08:03 PM   #1
PLANETGETLOW
Trailing Arms From Scratch
I'm going to make some out of 2x2 box tubing, but would like to know what people have used on the ends?
Is there a kit?
Are people just using bushings?
Are some using Heims?
Has anybody ever used the ends off of the leaf springs?
PLANETGETLOW is offline   Reply With Quote
Old 11-19-2011, 08:08 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Trailing Arms From Scratch
Member Nuke1 built custom arms for his truck and did how to:
http://67-72chevytrucks.com/vboard/s...d.php?t=321100
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 11-19-2011, 08:26 PM   #3
PLANETGETLOW
Damn, nice TA's!!
Old 11-19-2011, 08:28 PM   #4
PLANETGETLOW
Also, since my son's truck was a leaf setup, if I find a pair of TA's from a 70's model truck will those work?
(Truck is being bagged with a full notch)
Old 11-19-2011, 08:38 PM   #5
BMERDOC
BMERDOC's Avatar
I think all the trailing arm from 60-72 are the same. So as long as you add in the trailing arm crossmember and a centering device (panhard rod, watts link) you should be ok. That is assuming it is 60-72.
Nick Carter
