Old 11-19-2011, 10:51 PM   #1
82Cecil
82Cecil's Avatar
Gasoline odor no visible leaks
SWB C10 stock 6.0 liter, with 1 3/4" headers and 3" inch exhaust. using fuel cell above the bed. new steel braided fuel lines. Aeromotive A1000 on frame.
The oder seems to be coming from the rear and below but there are no seepages around the fittings. The AN fittings do have a small hole in them but I'm grabbing at straws with that. I would think if this had anything to do with the odor, liquid would soon be present.
After letting it set for 3 days the oder is still stong. the fuel cell vent is capped.
Engine has had a performance tune recently but the oder was present before the tune. I've sniffed the exhaust, it does not appear to be the source
Any ideas ??
Any tools that would help locate the source of the odor? (not a lighter)
Thanks for your help.
82Cecil is offline   Reply With Quote
Old 11-19-2011, 11:26 PM   #2
Goldfinger
Goldfinger's Avatar
Re: Gasoline odor no visible leaks
get a bottle of soapy water and spray down the lines. bubbles will tell you about a vapor leak. fuel vaporizes readily and can cause the odors.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 11-20-2011, 01:59 AM   #3
stroker87
did you remover your stock tanks & hoses, maybe your smelling them?
stroker87 is offline   Reply With Quote
Old 11-21-2011, 10:14 PM   #4
82Cecil
82Cecil's Avatar
I will try some soapy water, thanks.
The old tank and lines have been removed.
Old 11-21-2011, 11:22 PM   #5
1LowToy
Two ways I can think of:
1) If you have access to an exhaust gas anylizer sniff around with that. Hi HC reading is raw fuel.
2) The smog testing shops here in cali are checking the fuel evap systems for leaks. Yeah one of my cars had a leak. They put in smoke into the fuel tank under very low pressure and sure enough there was a hose disconnected under the car. The found the problem within a minute.
If you still have your evaporative emissions canester connected to the carb and halfway connected it may coming from there.
1LowToy is offline   Reply With Quote
