Old 11-20-2011, 02:26 AM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
ceramic pads, your opinion?
so about two months ago i spent money on some nice top of the shelf o'riely ceramic pads for my truck
the no brake dust on my tt2's is nice but,
it seems like during the summer if the pads got just a little to hot they fade damn quick and smell pretty bad when you brake hard then stop and get out
now during the winter they work great anybody else think ceramics are a bunch of ? or is just me expecting to much for consistan pads?
i have half vacuume from a big cam but even so when your driving there is enough to make full functioning brakes
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-20-2011, 08:48 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: ceramic pads, your opinion?
First I've heard of that, I thought they had superior stopping power in any situation but wore the rotors faster.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-20-2011, 01:34 PM   #3
INSIDIOUS '86
seems quite the oppisite in fact,
been digging around in other forums, seems like the problem i have isnt to uncommen for spirited drivers on ceramics
Old 11-20-2011, 02:15 PM   #4
68Timber
68Timber's Avatar
I thought I saw an ad somewhere that ceramics were the choice of nascar? I'm trying EBC next time.
John
74 Honda Z50 build
Old 11-20-2011, 03:16 PM   #5
njlimbaugh
Over the last few years (maybe, 40?) I've tried about every type of pad/shoe out there. Metallica, ceramic, etc. etc. I've finally settled on stock type pads/shoes for the simple reason that they're designed for everyday driving in everyday traffic. If you're going to go racing it's a whole different story. I've never had to replace any shoes/pads after the first time. Even with daily driving they always last me until I trade or sell the car/truck.
njlimbaugh is offline   Reply With Quote
Old 11-20-2011, 03:19 PM   #6
ozark
For what my opion is worth, I have had better luck and wear with the cheaper pads than the higher priced ones. I haven't noticed any difference in stopping or fadeing between the different grade of pads.
ozark is offline   Reply With Quote
Old 11-20-2011, 03:36 PM   #7
navysnipe
navysnipe's Avatar
I went with ceramic on my 01 silverado. It has 4 wheel disks and the parts guy said the ceramic was what was stock. I don't have a problem with fade or anything like that, they stop great, but they squeal, even with the spray on goop you put behind the pads. I finally got them to only lightly squeal but squeal they do. Never had that problem with non ceramic. I even changed the rotors and checked the runout. still squeal.
Navysnpe
navysnipe is offline   Reply With Quote
Old 11-20-2011, 09:21 PM   #8
INSIDIOUS '86
well when i go to the track after a couple of corners the brakes are done and even when its cold outside so its seems the heat range of the pads are for daily driving and and sunday drivers, so much for getting what you pay for, a 20$ set does the same thing above
Old 11-20-2011, 09:54 PM   #9
Gyawo
In a DD vehicle, always use OEM brake material. If the vehicle calls for ceramic, use ceramic, calls for semi metallic use semi metallic, etc etc. Ceramics are always going to be a little noisier than other materials, I believe it is because ceramics are harder than other friction materials, been a while since I have looked at my modules that explain the differences.
Gyawo is offline   Reply With Quote
Old 11-20-2011, 10:20 PM   #10
68Timber
68Timber's Avatar
For a good dozen years solid now I've been getting the mid-grade pads from the Zone. Lifetime replacement that I've never needed and only had one or two sets that squeaked a little before quieting down. But that blonde on the EBC commercial has me convinced I'm missing out on something somehow...
John
74 Honda Z50 build
Old 11-21-2011, 12:38 AM   #11
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
Ceramic pads sacrifice stopping power for lower dusting characteristics...semi-metallics wear the rotor more, but create better friction. Semi-metallic pads can be MANY different compounds, so not all semi-metallics are the same.
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 11-21-2011, 02:30 AM   #12
VH Coachworks
VH Coachworks's Avatar
Personally I dislike ceramic pads for a DD vehicle. As stated above, they are noisy, hard on rotors, And if the rotor isn't 100% true, it will amplify the pulsation into the pedal 10X more then the others in my opinion. In my experience, I've found that the lower price pads, prove to work out the best for a daily. I've had very good luck with NAPA's OEM grade line TruStop, I believe?
VH Coachworks is offline   Reply With Quote
Old 11-21-2011, 09:22 AM   #13
BigBlocksRule
I'm using AC Delco ceramics for the first time. They're noisy as hell but zero dust. I had the rotors turned when I went to these brakes, they still look fine. I've had zero issues with fade.
BigBlocksRule is offline   Reply With Quote
Old 11-21-2011, 02:23 PM   #14
INSIDIOUS '86
well i have no probs with pulsing or sqeaking just the bite fades rather drasticly with heat
