Designated A-hole!
I need to get my old steering wheel off, but it won't come!!!
whadda I do, I got a puller and have tried beating on it with it under tension. I tried heat, but I almost set the truck on fire. what else can I try?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Spray it with penatrating oil. Put the puller back on it, and while it is under a good load, leave the nut on the shaft, just enough to cover the end of the shaft, then while it is under a load with the puller, get a big hammer, and hit right on the nut. It should move. Once you get it off, before you put it back on, use some antisiese on the shaft, so next time it will come on off.
Sam
72 LWB chevy truck. Pasadena, Texas |
You know what? I meant to say hit the puller shaft.
Sam
Designated A-hole!
I am gonna go get some penetrating oil, hopefully I won't have to get out the portaband!
![]() ![]() Join Date: Jul 2002
Glad you got it off krue.....yoiu saw where mine ended....with the shaft!!
Designated A-hole!
Yeah, I got it off, but now I gotta find my thread file. And find the thread where thely discussed using the S-10 wheel.
GYRO GEARLOOSE
Strongest puller: Use grade 8 bolts, tighten up, hit center of puller.
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
I used a regular puller, and tore the he$$ out of it getting my old one off, but it was trash anyway..
![]() 350/350 3.73 Next; 335hp GM Crate |
