Old 11-20-2011, 05:00 PM   #1
ryans69chevy
Putting a Big Block in a C10
For you guys that have put big blocks in these years of c10's what kinds of things did you do to your trucks to compensate for the extra weight and power? Upgrade suspension any? Disc brakes all the way around or just in front? Or does the suspension even need to be improved since some of these trucks came with big blocks from the factory. My '69 currently has a 307, so maybe it doesn't have some of the same compenents that the big blocks came with. I'm not sure though.
ryans69chevy is offline   Reply With Quote
Old 11-20-2011, 05:03 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Putting a Big Block in a C10
Big block springs in front (i think), different tranny, bigger radiator, different motor mounts. Even the older BB trucks had drum brakes all the way around.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-20-2011, 05:58 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
My 72 long box C10 came from the factory with a small block and has a 396 now but had the heavy duty front and rear springs ( coils all the way around) and the truck sits, rides and handles as it should.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-20-2011, 08:17 PM   #4
ryans69chevy
How do you know if the springs are heavy duty or not?
Old 11-20-2011, 10:46 PM   #5
1972RedNeck
1972RedNeck's Avatar
If they are stock, the spid should say "heavy front/rear spring" if they are heavy.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
