Old 11-20-2011, 06:27 PM   #1
FLcustom10
Horn assistance needed
I've searched through as many threads as I can and I still don't understand which order the horn contact, spring, and plastic piece go in. Is it like I have it shown in the picture with the head of the contact going in first? If so the head is too big to fit in the plastic. I think the LMC catalog is wrong.
FLcustom10 is offline   Reply With Quote
Old 11-20-2011, 08:44 PM   #2
JimKshortstep4x4
Re: Horn assistance needed
The spring goes in first and then the horn brush. The setup is made this way so the spring can keep the horn brush in contact with the horn disc. It does not matter if the spring and horn brush are not held in since they point upward when installed into the steering wheel.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-20-2011, 08:50 PM   #3
FLcustom10
Is the horn brush the bolt looking thing? Does the head go in first(after the spring)? It won't fit inside the plastic tube? I can dremel tool it down, I just want to be sure that's the right thing to do.
Old 11-20-2011, 09:25 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I've heard the LMC ones are pretty crappy. Here's a thread from sometime back you might want to peruse. Doesn't seem to give a definitive answer to your quetion but they do give encouragement..
http://67-72chevytrucks.com/vboard/s...d.php?t=345967
68gmsee is offline   Reply With Quote
Old 11-20-2011, 11:01 PM   #5
FLcustom10
Thanks guys. It looks like the answer is to dremel tool the head down until it fits in the sleeve --(spring first!). I should know by now not to expect after-market parts to fit, but it's frustrating when you don't have an original to look at and you have to re-do things multiple times because the parts don't fit like they should.
Old 11-22-2011, 10:28 PM   #6
FLcustom10
I got it to work. I had two sets of contacts. One came with a steering wheel and when I temporarily lost that I ordered another set. lol One of the contacts was about half the length of the one shown in the picture. That's the one that worked after dremel tooling the head down so it would fit in the sleeve. Spring, then contact (head first), then plastic piece.
Thanks for your help guys. Horn sounds good.
