Old 11-20-2011, 11:19 PM   #1
thejed72
is there a simple way to remove fuse terminals from the fuse block?
I need to clean up my wiring harness and fuse block and the terminals. I have a rust on them from a previous leak and repair a few hacked wires. Is there an easy way to remove the fuse terminals from the block itself to clean up the rust? I can get them out with a few small screw drivers and time, but there has to be an easier way.
'69 GMC by the way.
thejed72 is offline   Reply With Quote
Old 11-21-2011, 12:07 AM   #2
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Re: is there a simple way to remove fuse terminals from the fuse block?
I got a freebie harness from a member here. Wiring was un-cut and solid, but fuse box had a fair amount of surface rust and corrosion. I washed it with some Naval Jelly and then sat down with my DREMEL with a 1/8" burr. Cleaned all the fuseholders and it works great. Just took some patience and several adult beverages, but it serves me well.
TobyArnot is offline   Reply With Quote
Old 11-21-2011, 12:51 AM   #3
thejed72
Did you remove the terminals, or do it with them installed in the block? I don't want to snap any connectors or damage the block trying to het them out.
Old 11-21-2011, 01:04 AM   #4
TobyArnot
TobyArnot's Avatar
I didn't try to remove the terminals. I didn't want to "screw it up", something I excel at. I just sat at the workbench with a big towel in my lap to catch the "crap". Ran the small burr down in the actual curved fuse clips. I kinda' felt like a dental hygenist, cleaning all those cavities. Seriously, I probably spent a couple of hours cleaning it up. Considering the going rate for a "new" harness (~$300+), I think it was time well spent.
