Old 11-21-2011, 01:44 AM   #1
slick78
Gear ratio???
Can anybody please tell me what gear ratio i have in my 78 c10?. It has a straight six 250ci,it came with a 3 speed on the colom but i changed it to automatic turbo 350 tranny. Thanx!
slick78 is offline   Reply With Quote
Old 11-21-2011, 01:54 AM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Gear ratio???
My 68 292 has 3.73 gears with a 4 on the floor
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-21-2011, 02:54 AM   #3
slick78
Re: Gear ratio???
I think thats what i got 3.73's, but iam not too sure.
Old 11-21-2011, 07:18 AM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Gear ratio???
Per the Powertrain Chart in the archives at the GM Heritage Center, base axle ratio is a 3.07:1.
http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf (page 5)
Optional ratios are usually shown on the SPID label. Do you still have the SPID label on it? Does it show a ratio on the label, like "GU6" (3.42) or "GT4" (3.73)?
At any rate, all this assumes it's never been changed. The only way to know for sure is to pull the cover and count teeth. Change the fluid while you are in there -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-21-2011, 07:20 AM   #5
Keith Seymore
Re: Gear ratio???
As an aside, if you have the ability to travel a measured distance in a certain amount of time, then we can calculate the rear axle ratio using the "N/V" ratio formula.
Let me know if you want more detail on that.
K
1979-1986
1986 - 2019
Old 11-21-2011, 08:04 AM   #6
D13
D13's Avatar
Re: Gear ratio???
My 84 250/TH350C has 3.08's
My 81 3/4 ton 250/3OTT has 3.43's
My 77 250/3OTT has 2.7? 's
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-21-2011, 08:27 AM   #7
Keith Seymore
Re: Gear ratio???
Shown on page 15 as well - 3.07:1 standard.
K
1979-1986
1986 - 2019
Old 11-21-2011, 12:26 PM   #8
slick78
Re: Gear ratio???
I just changed the fluid,but i forgot to check. Iam guna open up the cover again anyway because i got a little leak. Its more likely my gasket. Then this time ill count.
Old 11-21-2011, 12:35 PM   #9
slick78
Re: Gear ratio???
Gmheritagecenter helps alot. Thanx!
