11-21-2011, 07:08 AM | #1 |
My budget build/fix up 90 SWB Cheyenne
Ok so I picked this up from my moms co-worker for $300 bucks good tags till 7/2013 4.3L th700r4 ran like crap when I picked it up would rev up out of gear good and then in gear big loss of spark turns out so far just needed a tune up did that and have put about 60 miles on it since seems to be running good still a bit cold blooded but goes good. I will been looking to swap the front for a dual head light set up and grill.
So what all do I need for the other set up core support ect... I'd like to lower it, can you guys input on the lowest I can go with out c-notching or having to run different inner front fenders. Also cheap lowering methods? Pros and cons maybe? Here's some pics of how it looks now. |
11-21-2011, 09:12 AM | #2 |
Re: My budget build/fix up 90 SWB Cheyenne
Good deal for $300
11-21-2011, 11:02 AM | #3 |
Frequent Flyer
A 2/4 drop is what you want if you do not want to c-notch it.
The worst part of a 2/4 drop is the hanger swap involves grinding the rivets of the factory hanger to bolt in the new ones. The front would just be a spring or spindle swap to get the 2" drop. I would consider do a 4/6 with a bolt in notch if possible. You wouldnt have to change inner fenders or anything with the right tire size. |
11-21-2011, 08:25 PM | #4 |
laying low
Shoot yeah. $300 and it drives? Good deal for sure. I'd like to find one like that.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-21-2011, 10:17 PM | #5 | |
"Oh well, it's a driver."
Ooh, modern shop truck!! Needs some faded lettering on it.
And like JWall said, 4" is as much drop as you can get in the back without a C-notch. Have you looked in the junkyard for a front fender yet?
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E Quote:
11-22-2011, 02:21 AM | #6 |
Yeah there's fenders at the yard I'm sure couple on cl too seen some on there for $30 have to wait till I have the funds also want to do the grill and light swap.
