th 350 crossmember
What side faces the rear of vehicle? 1971 c10 pick up one side has 4 holes and one side has one hole near the trans mount thanks for the help. I do have the upper mounts but are removed in the pics
Fuzzy |
Re: th 350 crossmember
On mine, the single hole is to the front, 4 holes to the back
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Thank you dfwright
Fuzzy |
If you look at the cross member closely you can see that it is angled. You will want to install the cross member so that the it angles downward from front to rear.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
