Old 11-21-2011, 12:47 PM   #1
DANTIP
DANTIP's Avatar
Thick or thin Carb Base Gasket????
I've seen both thick and thin carb base gaskets. Is one style recommended over the other? I need to mount a Q-Jet and would like some feedback before picking up a base gasket.
DANTIP is offline   Reply With Quote
Old 11-21-2011, 01:04 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Thick or thin Carb Base Gasket????
most q jets used a thick gasket also helps with heat so fuel does not boil
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-21-2011, 01:13 PM   #3
406 Q-ship
406 Q-ship's Avatar
^^^ yeap
It does depend on the intake mainfold your running. A stock Chevy intake with the exhaust passage at carburator pad will require a specific base gasket. If I remember correctly there is a weird iron intake that the thick gasket will not work with due to the gasket not covering the openning properly, it will end up with a big vacuum leak (ask me how I know). For all the spread bore aluminum intakes from the aftermarket, use the thick base gasket and you'll be fine.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 11-21-2011, 03:54 PM   #4
red71c10
The Red Menace
red71c10's Avatar
For now I have replaced my Q-Jet with a Holley 650 which is a direct swap. I'm using the thick gasket on the stock manifold and it works fine.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 11-21-2011, 04:05 PM   #5
71c10bbsuper
71c10bbsuper's Avatar
every chevy motor with a qjet came with a thick gasket
71c10bbsuper is offline   Reply With Quote
Old 11-21-2011, 04:30 PM   #6
vectorit
What?
vectorit's Avatar
My 1968 327 with original cast iron intake/q-jet has always run a thin gasket, with a stainless steel base to keep the gasket from burning up. The gasket material has metal in it, so it's not the kind of gasket one could tear with bare hands.
IIRC the thick cardboard gasket with the plastic in the bolt holes didn't really get popular until the early '70s?
I haven't seen that steel base for sale, since I have just grabbed them when I saw them on a junk pile.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-21-2011, 05:22 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
just like my pizza crust ----thick
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-21-2011, 06:30 PM   #8
406 Q-ship
406 Q-ship's Avatar
Yours is one of those that I found to have the exhaust under the carb. Those are the ones that always need the stainless steel in the gasket. I believe the thicker gasket came to be after 1969.
