Old 04-19-2003, 07:57 PM   #1
dennisr
Check out, just lowered and have lowering question
Before
dennisr is offline   Reply With Quote
Old 04-19-2003, 08:05 PM   #2
Stroker
Well it looks good in the before pic. So lets see the after. You'll need to make two post for two pics, at least thats what I have to do. How much did you drop and how?
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 04-19-2003, 08:05 PM   #3
dennisr
After an Early classic rear air ride, and 2.5 drop sindles and 1.5 drop springs.
I would actually like the back a bit lower, but I am only 1 inch above the bump stop as it is. Being that close I may have to raise it a bit more. What can I do to get another inch in the rear. Can I cut down the bump stops a little? Or is a c-notch required to get any lower? I have yet to drive it lowered because I need to pick up a new tie rod end in the morning. So I'm not sure if I'm already too close to the bumps stops already or not.
Thanks,
Dennis
Old 04-19-2003, 08:19 PM   #4
Stroker
Your truck looks good with the new additude. I don't see any problem with trimming down the bump stop. I think I've seen a few post where people have done it for the reasons you mention. Just so you have a stop before the axle or pumkin make contact with anything like the bed or frame. I think I've seen some progressive type bump stops somewhere. Slight contact is pretty much absorbed as it compresses it stiffens up.
Oklahoma
Old 04-19-2003, 09:16 PM   #5
Randy70C-10
Randy70C-10's Avatar
Very nice!! The late model bed looks cool. Not sure if I'd lower it any more, it looks perfect like it sits now.
Randy70C-10 is offline   Reply With Quote
Old 04-19-2003, 10:43 PM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
No problem trimming bump stops. I trimmed about 1 inch off mine and when I got the flip kit for the rear of my '77 it came with really thin (1/2 inch) polyurethane bump stops as replacments.
BTW your truck looks great!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
