Old 11-21-2011, 02:35 PM   #1
RestoreAmerica
Putting Disc Brakes on a 69
Hello,
I am looking for a how to on changing my 69 to front disc brakes. Any advice is appreciated. I plan on purchasing this kit http://stores.intuitwebsites.com/hst...END/Detail.bok and putting it on. I will also put new calipers, bearings, and maybe new rotors. What do I need to take off a 71/72 to complete the task?
Thanks!
RestoreAmerica is offline   Reply With Quote
Old 11-21-2011, 04:48 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Putting Disc Brakes on a 69
I believe you'll need the front steering linkage from the 71/72, as well as the spindles...I'm sure I'm missing something....
Also, let us know how you like that kit....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-21-2011, 07:28 PM   #3
71 super
71 super's Avatar
You will need the drag link (long connector between steering box and idler arm)and spindles from the 71-72, everything else will work in the kit. It is pretty straight forward, but you will need to get a disc drum prop valve and front brake hoses that will adapt to your setup. I personally have used the kit from GMC pauls several times with very good success. In fact I will doing this again over thanksgiving break to the 1970 CST.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-21-2011, 08:17 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Before you make your final decision on where to buy from please take a look in the forums "Vendor Marketplace. We have some really great vendors that support our forum and would love to have your business.
In the meantime I would spend some time reading this "Drum to Disc" conversions 60-70
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-21-2011, 09:20 PM   #5
RestoreAmerica
I would be happy to purchase parts from a forum sponsor with competitive pricing. I only posted that link cause it appeared to be reasonably priced complete kit. I have this 1972 Donor truck that has the proportioning valve and probably everything I need. My only concern is that while the truck is apart it seems that it would be wise to replace everything that could possibly be worn. Has anyone had any success unbolting the entire complete front suspension? I have another 71 that I spent a few minutes on with a socket and breaker bar with no success. Someone told me you could just remove a few bolts and take the entire front suspension off. I don't know if that is a huge advantage because I will want to replace A frame bushings, ball joints and everything anyhow. I would love any input and would be happy to read any posts already written on how to do it. I would like to have a pretty good idea what I am going to do before I tackle it.
Thanks!
Old 11-21-2011, 09:45 PM   #6
brans72
Hope that picture is not the donor truck in above post cause it looks super nice from what i see.
brans72 is offline   Reply With Quote
Old 11-21-2011, 09:48 PM   #7
RestoreAmerica
That is the donor at least for the proportioning valve and master cylinder probably the rotors/spindles too. Motor gone. Cab for sale. Doors rusted and missing vent windows. Long story and too much missing.
Old 11-21-2011, 10:00 PM   #8
RestoreAmerica
Have this one also but don't have the proportioning valve or master cylinder and the rotors look pretty beat. Motor and bed and rear end gone off this one now.
Old 11-21-2011, 10:19 PM   #9
gcburdic
Restoration Virgin!
gcburdic's Avatar
Off the top of my head...remove the 2 bolts that come thru the upper x-member, the top shock bolt, the pitman arm and the idler arm...
Geoff with a G
Old 11-21-2011, 10:32 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, you can swap the entire crossmember and all the components at one time. Since you are planning a rebuild, it won't be much of an advantage because you will be breaking it all down anyway.
Articles-
"Refining Sierra"
Old 11-22-2011, 01:33 AM   #11
blime81
Laid Lo
blime81's Avatar
I'm of the opinion that since you are gonna tear into it you on might as well just do it all while you are already greasy and swearing at bolts!
New ball joints, bearings, bushings and such, plus cleaning it all up might take a bit longer but not having to sweat that stuff for 40 more years is worth it I think!
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 11-23-2011, 08:24 PM   #12
DARIO1
You said the cab is for sale on the white donor truck? I would like to see some pictures of the obvious spots that are usually rusted out and general condition please. Thanks
DARIO1 is offline   Reply With Quote
