Old 11-21-2011, 03:07 PM   #1
tbs98z
tbs98z's Avatar
Need Vin help!!!
Trying to locate my vin on a 1979 C10 Custom Deluxe.I have looked in the obvious places,dash corner,door pillar and under hood and firewall,no dice.The engine is not original,so no help there either.Are there any hidden vin plates or identification markers anywhere else?
1979 C10 SB CUSTOM DELUXE
1998 Z28
2005 Trailblazer
2008 Silvy
tbs98z is offline   Reply With Quote
Old 11-21-2011, 03:38 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Need Vin help!!!
Yes. On the top horizontal flange of the frame rail, midway (fore/aft about where the seat would be), and I believe it's on the driver's side.
You will need a mirror, or to remove the cab in order to see it.
Should be one on the side of the trans as well, if the trans is original.
There are none stamped elsewhere in the cab sheetmetal (not like F car, for example, where there is a secret VIN under the heater box).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-21-2011, 04:06 PM   #3
J Knight
J Knight's Avatar
Keith, the Admins should give you your own sticky on the top of this board for stuff like this. The amount of OEM info you have with your back ground is awesome. Maybe call it "Ask Keith" The 73-87 OEM Q & A Board.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-21-2011, 04:09 PM   #4
Keith Seymore
...no pressure.....
(lol)
I may not be correct on which side, because I can never remember - but someone here will know fer sure.
The rest of it I am pretty sure of
K
1979-1986
1986 - 2019
Old 11-21-2011, 04:32 PM   #5
tbs98z
tbs98z's Avatar
Thanks Guys! I appreciate the help!!!
1998 Z28
2005 Trailblazer
2008 Silvy
Old 11-21-2011, 05:02 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Great idea,by the time they read it all 99% the questions would be answered ,
a Dear Abby for Squares lol
the 78 jimmy/burb vin plate, by the striker pin, in the jamb
79 jimmy vin on dash...look for the holes and flat area...
my 78 has a late 80's dash pad, from outside...looks like no Vin....been called a hack job lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-21-2011, 08:50 PM   #7
old yelr
On my 79 K10 the vin is stamped on the top of the passenger side frame rail just behind the cab, about a foot or so. I was actually surprised to see it there when I pulled the bed off. Maybe yours is there too
old yelr is offline   Reply With Quote
Old 11-21-2011, 10:13 PM   #8
6772fan
Active Member
6772fan's Avatar
Another possibility is that the dash pad was replaced with an earlier version, thus covering up the VIN plate riveted to the driver side metal dash below the dash pad. I believe 79 was the year where VIN's were moved to the dash area.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 11-22-2011, 08:45 AM   #9
Keith Seymore
I thought of that, too, but checked the LMC catalog which seemed to indicate the move didn't happen until 81 (which didn't sound right to me).
Wouldn't hurt to check that.
K
1979-1986
1986 - 2019
Old 11-22-2011, 09:01 AM   #10
tbs98z
tbs98z's Avatar
Yes Sir 6772fan,you were correct!There dash pad was an earlier version,although it looked like the Sahara Desert,don't know why it was replaced. Thanks for all your helpful input guys!!I am sure I will have to call upon your knowledge several times during this rebuild,when it actually starts.I appreciated it!!
1998 Z28
2005 Trailblazer
2008 Silvy
Old 11-22-2011, 11:49 AM   #11
old yelr
Yeah, they moved it up to the dash in 1979. My 77 has it on the door frame by the striker bolt and my 79 is up on top.
