1998 chevy 3500 2WD to 4WD
I have read many threads of converting to 4wd, but all are for 1/2 ton trucks, is it possible to convert a 1 ton to a 4x4 I am talking about the GMT 400 series trucks I know of the offroad unlimited solid axle conversion for 1/2 ton trucks;
http://www.offroadunlimited.com/orus...?idCategory=18 will this fit 1 tons? are there any kits like this for one tons?
'69 K20 292 4spd 4x4 - project 27,000 orig. miles '98 1500 suburban 4x4 - driver 219000 orig. miles |
Re: 1998 chevy 3500 2WD to 4WD
This kit should work because the difference is the height of the frame rails. The easiest way is to get a 73-87 Chevy and use the axle, front springs, front hanger from the front axle, and rear hangers from the rear axle along with the tranny/transfer case. If done correctly you can use your original tranny.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Local Redneck Authority
If you opt for a F**d axle, it will be the same side drop as your current trans/t-case setup.
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
the truck is 2wd so no transfer case currently
good call, sorry about that one
![]() I guess it would allow for the same year trans/t-case to be swapped in, that's the 4l60e or the 4l80e trans, right? Why go back to something like 700r or th350 if you don't have to?
To run a 205 or 208 t case http://www.offroaddirect.com/Transfe...mber_p_45.html or if you want a 4 link with coilovers but you gotta weld to use it http://www.offroaddirect.com/88-98-C...vers_p_12.html
I am not sure what the difference in those years frames is.
I found this. http://www.sky-manufacturing.com/new...duct.php?id=64 Give them a call and see if it'll work with your 1 ton. |
