Old 04-19-2003, 08:28 PM   #1
jamesi20
jamesi20's Avatar
Bucket Seats
I AM DOING A FRAME OFF RESTORATION ON A 70 CUSTOM 10 AND WOULD LIKE TO PUT BUCKET SEATS WITH A CONSOLE IN IT. SICE I AM FAIRLY NEW TO THESE TRUCKS MY QUESTION IS ARE 69-72 SEATS ALL THE SAME? I THINK FROM READING POSTS HERE THAT 67-68 ARE DIFFERENT BUT I AM NOT SURE ABOUT 69-72? ANY HELP WOULD BE APPRECIATED,THIS IS AN AWESOME SIGHT THANKS
jamesi20 is offline   Reply With Quote
Old 04-19-2003, 09:36 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
All are the same except for seat cover scroll design. 69/70 used a single scroll pattern in the center of the seat cushions, the 71/72 style have 2 scrolls on either side of ceat center. Both cover styles are available in repro.
Pass side brackets are different between trucks and Blazer's other than that the seats are the same between models.
You can use 73-up lowback truck.blazer buckets and the correct 69-72 seat covers and get a resonably close match
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-19-2003, 09:40 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
seats
The 69-72 bucket seats are the same. 67-68 buckets look totaly different. The 69-72 blazer/jimmy buckets look the same, but there are some little differences. (in brackets and backs) If you are going for "true" stock, 69-72 pickup buckets is what you want. Hope that helps.
too much stuff is offline   Reply With Quote
Old 04-19-2003, 10:53 PM   #4
Rod
But some suburbans and blazers used buckets that have metal backs and use a different style cushion which would not be correct in a truck.
This pic here shows the 3 types of seat available for trucks.
The blues on left are 67-68 truck buckets.
The center Black are 69-70 Truck buckets with 1 scroll.
The right side white ones are 71-72 with 2 scrolls... there was a highlander pattern seat skin available also. Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-20-2003, 08:38 PM   #5
jamesi20
jamesi20's Avatar
THANKS
MAN,YOU GUYS ARE AWESOME!!! THANKS A MILLION
