Build me a motor!!!
Now that I have your attention, give me your ideas on a high winding sb...
I'm thinking 5.3 LS Or 350 block, 307 crank, 327 pistons and some compression!! Now this isn't for a truck or the street but I would like it to run on 91 but race fuel and spray aren't out of the picture... I'm on a budget too... I have to buy the LS but have some parts for the other motor... 5.3 carbed with a 100 shot? 331 11-1 sbc /na Going in a 95 camaro.. Posted via Mobile Device
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Re: Build me a motor!!!
You are leaving a lot of power on the table with a 5.3 bore spacing. You can get the same rpm's from an LS3 block and the much better 4.08" bore spacing.
Heck, you can even run 8,000-8,500rpm with a well prepped 4.0" crank. Why limit yourself to a 5.3 liter when you can build a 418" motor with the above specs? The thing you need know is more about the heads, cam and intake. A Nice set of AFR 245's with a good sized solid roller and single plain intake will get you there. Oh wait, you are on a budget.. That just killed your high RPM rever. You are better off sticking to a hyd motor and 7,500 rpm. With that you can find a set of good heads for a 3.905 bore. That would be your best budget option.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Ok Shon you may have lost him. You lost me. LOL I know you know the Ls stuff does he need to start with a 6.0 liter motor or what?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#4 | ||
I was recomending you start with a new LS3/L92 block ($1400ish). They come from the factory with a 4.065" bore and can be taken out to 4.08" safely.
Here are factory bore specs: 4.8 / 5.3 = 3.78" 5.7 = 3.899 6.0 / LS2 = 4.0" LS3 / L92 = 4.065" The problem with the smaller bore blocks is they tend to shroud the intake valve and do not allow for maximum air flow. With a NA motor it can reduce power fairly dramatically. You are much better off starting with a 6.0 block, it's cousin the LS2 which is an alum block or its big mean uncle, the LS3 / L92 in alum. If it is RPM you are after, a stock 3.622 crank will go upwards of 8,500 when balanced. Even the Callies 4" cranks will go 8,000+ when balanced. All I am getting at is don't limit yourself to a small cubic inch motor thinking you can't push a bigger motor to the same rpm. To get the RPM, you are going to need the heads and valvetrain to do it. I would feel safe spinning a hyd cam to 7,500 (I have heard rumors of the CTS-V class racing taking hyd rollers to 9,000 but I don't know the truth behind it). If your after 8,000+ rpm, you are probably going to want a solid roller set up. Be prepared to open your wallet. I hope that helped..
Well I'll tell you this, I'm LS stupid! I haven't played with these motors at all so when I wanted a high winding motor I was referring mostly to the gen 1 I'm used too with the destroked high comp like the old 302 sbc. If I go LS its going to have to stay mostly stock due to buying cost and changing from gen 2 to LS underhood...if I go LS probably put a cam/head combo on it and be done.. Thanks for the info now I just need to start getting parts...
If you are staying NA with an LS, find a 6.0 block. It's worth the extra few hundred dollars for the power gain you will see, let alone the drivability. 5.3 to 6.0 = 13% increase in cubic inches.
The added inches + Unshrouding of the valve + Ability to tame the same sized cam (or run a bigger one) = Much happiness!!
Ok I'm on the hunt to see what I can find local... Thanks guys... Hey super73 how's your truck going?
Still at the chassis shop, but it is getting lighter and going to go faster
