Non Truck Stereo Speaker ?'s
In our 02 TransAm, the rear sail panel speakers don't seem to like Pantera or FFDP....
The originals lasted several years & then puked. The 1st replacement GM speaker set lasted a couple of years. The 2nd set is now crapped out & these are getting difficult to source. This is just the complete factory system (monsoon) consisting of the OE head unit, 2 door speakers (separates), the 6x9 sized mid-range sail panel speakers (they're actually a little smaller than 6x9's), & a small sub in the rear hatch area. But, they tell me I can't just pop in any old 4ohm speaker as these are apparently 2ohm. Readily available stuff isn't easily swapped & I have zero interest of ripping it all out for a new system. Any suggestions for a quick & painless (labor & cost effective) swap for the sail panel speakers that won't require swapping any of the other equipment?
Re: Non Truck Stereo Speaker ?'s
you can use 4 ohm just do bother sides...
lots of aftermarket run on 2ohms anyways.. as long as if fits it'll work. just be a bit quieter.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
Mongoose is spot on. You may also find that if the new speakers have a better sensitivity rating than the ones you are replacing then the sound may be just as good/loud or even better despite possibly being higher ohms than as original. So I would say get the best 6 1/2" 4 ohm speakers your budget can afford if you don't want to dig too far into it.
I believe the monsoon systems in those cars used quite a varied combination depending on vehicle year/model: Combination of 2 and 4 ohm speakers, some being single voice coil and some being dual voice coil speakers (is there 2 each or 4 each wires going to the sail panel speakers?) and the amp filtering some of the speakers as well (like probably the highs are filtered out of those sail panel speakers so the speaker is more of a subwoofer/mid-range driver vice a coaxial)....so you may want to double check/research a bit more to find out for sure what "should" be there if it really matters to ya. Last edited by 86Burban; 11-23-2011 at 04:52 PM. |
#4 | |
My Harley came factory with 2ohm speakers (2) and I replaced them with a pair of Polk 4ohm speakers. The sound quality was fantastic.... until you got up to speed. You couldn't hear them. The impedance affects the level of sound coming from the speaker.
Replaced them with Infinity 2ohm speakers and boom! Great sound and ample volume. If you replace a 2 ohm speaker with a 4 ohm it may not be capable of getting loud enough for your taste. I have the Monsoon system in my '05 Bonneville that has 6.5" separates in the front doors, 5.5" mids in the rear doors and 6"x9"s in the rear deck (might be 5"x8"'s actually). I want to replace the speakers at some point soon so I am curious to see what you end up doing. |
#6 | |
I did mention my No1 music choice is Pantera right? ![]()
you want your vol back, wire both speakers to one side in parallel,, two 4 ohm speakers in parallel will read 2 ohms.. you lose left to right control unless you add two speakers to the other side as well.. but in that car you may not have room.. it is just an option
run a pair of 5.25" in both sides in parallel (2 ohm) those cars are the same 82-02 the area will take a real 6by9 or the 2) 5.25" paired together
