11-22-2011, 12:22 PM | #1 |
Grandpa in the rustmobile...
How much extra threads on U bolts need to stick out to be able to run a drop block?..
Looking under my truck earlier, noticed I have a little over an inch sticking down past the nuts. How much extra threads will I need (say if I ran a 1" block) to stick out?
This make sense? I'll try to get pix And is it 7/8 or 3/4" hole?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-22-2011, 01:15 PM | #2 |
needs more $$$
Re: How much extra threads on U bolts need to stick out to be able to run a drop bloc
Given how many foot lbs is needed to torque these down, I'd be comfortable with just a few threads being visible...in fact, I cut mine down after torquing anyways.
I don't know the hole size, but I'm pretty sure the bolt size is 1 1/4".
1970 2wd Blazer |
11-27-2011, 02:42 PM | #3 |
TTT
I have 1 1/8" of thread sticking past the nut (maybe a bit more but 1 1/8" to be safe). So could I squeeze a 1" drop block in there
11-27-2011, 08:20 PM | #4 |
Happy to be here
I would replace the U-bolts and add the block you want. U-bolts are cheap to buy so why risk it.
11-27-2011, 09:13 PM | #5 |
U bolts are new....(less than a year..)
11-27-2011, 09:20 PM | #6 | |
67-72 parts collector,…
I drill my drop blocks with a 7/8" drill bit. The u-bolts should be 3/4" diameter.
11-27-2011, 09:35 PM | #7 |
So I wanna lil extra room-Do you think the 1 1/8" is enought to sqeeze a 1" block
11-27-2011, 09:41 PM | #8 | |
I use drop block to gain the maximum drop. My first choice would be drop springs.
11-27-2011, 09:48 PM | #9 |
Do they make a HD dropped spring lolife (you would know)?
I only want 1-3" (realize 3" shouldnt be attempted with a block).
11-27-2011, 10:27 PM | #10 |
Not that I know of.
11-27-2011, 11:55 PM | #11 |
I didnt know, thought burbs or 3/4 tons might have their own drop spring
11-28-2011, 12:01 AM | #12 |
i have heard that the burbs do have their own drop springs for the rear do to being heavier, as far as 3" blocks they can be done (i have some i made on my burb but i run 20" wheels) but no more than i believe a 2" block is recommended with 15" wheels
11-28-2011, 03:05 PM | #13 |
Called fastenall, there checking some prices for me on 2" u bolts (already have blocks ready).
Going down to Tampa Bay Fl area for the next 2 weeks, I located some spring shops so hopefully I can get some U bolts made on the cheap. Anyone know if they'll let you take 2 u bolts on a airplane, or should I try to flat rate box them to myself in TN LOL
11-29-2011, 12:14 AM | #14 |
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
11-29-2011, 01:32 AM | #15 |
seen it already-trying to do it REAL cheap if I can thanks for the link though others might benefit
11-29-2011, 02:11 AM | #16 |
Don't get too cheap.
It's your suspension you are talking about. Spend a few bucks and do it right. Contact member way2lo2. Posted via Mobile Device
