11-23-2011, 12:18 AM | #1 |
GM Shoulder Seat Belts in a Blazer
Have some aftermarket lap belts in my Blazer that suck. I was Looking for some factory GM seatbelts out of a 70's vintage car/truck that would work. I looked through the threads and couldn't find any good pictures. I have a roll bar. Could some of you post some pics of your shoulder harness seat belts in Blazers / Jimmy's. I was thinking of using thge 72-73 era exploding seatbelts (see images below). Need something to look for when junkyard hunting this weekend.
Shoulder Belt to bolt onto the roll bar: Lap belt which can be used by itself: |
11-23-2011, 11:46 AM | #2 |
Re: GM Shoulder Seat Belts in a Blazer
Since you have a roll/sport bar, Any of the pickup/blazer/suburb 3 point belt systems should work. Id look for one that puts the single latch & spool (retractor) at the base of the rollbar, or in the factory position at the rear base of the seats, the roller mount up on the rollbar at shoulder height, and the female buckle inboard of the seats. Just make sure your rollbar is mounted solid and reinforced well if you plan on tying your body to it.
http://67-72chevytrucks.com/vboard/s...light=shoulder |
