Old 11-23-2011, 11:34 AM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Exclamation Gas smell inside cab, problem found.
Started out as just a little smell, then more, then more. With todays ethenol gas, it just stank so bad inside my truck. Was a stale ethenol/gas smell.
Found the cab bolt mount was puncturing the tank. It was only weeping the gas out but probably not for much longer.
Time for that new floor I always wanted... Going to look for another cab I can rebuild while still driving this truck.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 11-23-2011, 11:41 AM   #2
splehigh
splehigh's Avatar
Re: Gas smell inside cab, problem found.
You should be able to weld that shut. lol Just kidding.
splehigh is offline   Reply With Quote
Old 11-23-2011, 02:40 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
ha, my buddy was driving a borrowed ford with duel tanks (his bud didn't tell him to not use one because it leaked) he filled it up and it started leaking he ran in the store and got some of that putty stuff the kind like teachers use to hang stuff on the wall ya know/ and sealed it good enough to get to where he was going.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 11-23-2011, 02:46 PM   #4
68gmsee
Active Member
68gmsee's Avatar
If it's a puncture it can be fixed with putty or emptied, flushed and soldered or brazed. If it's a rust pinhole, it's either time for a new one or have it flushed clean and recoated internally. Mine had rust pinholes and I got a Spectra.
68gmsee is offline   Reply With Quote
Old 11-23-2011, 03:27 PM   #5
bobs409
bobs409's Avatar
I just roughed it up and put some JB weld on it. Hope it holds, hate to have to remove it again.
I had the gas tank from my 66 Chevelle repaired once. A previous owner managed to put 2 pop rivets holes in it with his handy dandy trunk floor repair job.
When I picked up the tank, I asked if they filled it with water and they said no, just welded them up. Maybe it's not as dangerous as it sounds. ?
Bob
Old 11-23-2011, 03:40 PM   #6
no moa
no moa's Avatar
Time for a rear tank?
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
