Old 11-23-2011, 08:44 PM   #1
vettedad61
HELP When I step on the pedal the front fog lights come on?
on my 1972 When I step on the brake pedal the rear brake lights work as normal but the front amber lights in the front bumper come on? does anyone know how to fix it or where to start in the wiring to solve it? Thanks -Scott
vettedad61 is offline   Reply With Quote
Old 11-23-2011, 09:14 PM   #2
Yooper truck
Yooper truck's Avatar
Re: HELP When I step on the pedal the front fog lights come on?
Your hazard light (4 way emergency lights) switch is on. I am guessing you don't have turning signals either.
I bought my truck 2 years ago in California and drove it all the way to Michigan with this issue not knowing how to fix it. My switch was broken off, hazard fuse was pulled, and I had no turn signals. A little investigating when I got home and figured it out.
I hope it helps.
Yooper truck is offline   Reply With Quote
Old 11-23-2011, 09:40 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Weird. It does sound like something in the emergency light circuit though. Has it always done this or did you do anything to the column or wiring lately?
For some reason weird things are happening to our trucks in the last few weeks. I just noticed yesterday that on mine the left turn signal indicator light comes on when I turn the light switch on. Doesn't blink. Just turns the indicator on. Never did that before.
68gmsee is offline   Reply With Quote
Old 11-23-2011, 10:43 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
I hope it helps.
I agree mine was doing that the hazards were pushed in just enough to make contact but not blink (my knob was broke)
thats probably a blown bulb or loose ground making one of the left front/back lights not work my left front parking/turn light lost it ground and the green arrow would light when the lights were on.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-21-2012, 06:57 PM   #5
rener57
Same symtoms here. Is there is quick fix? somehting like pliers and pulling it back out. Here is picture (1970 C20 Cheyenne).
rener57 is offline   Reply With Quote
Old 03-21-2012, 06:58 PM   #6
rener57
Old 03-21-2012, 07:02 PM   #7
rener57
Sorry brand new member and was having issues with attaching picture.
My hazard light is broken and I pushed it in, as a result turn signals do not work and front amber lights come on when press brakes.
Is there a temp quick fix. What does the permanant fix look like?
Old 03-21-2012, 08:03 PM   #8
cdowns
cdowns's Avatar
amber lights in the bumper of 72's are not fog lights they are running lights/signal lights
Old 03-21-2012, 08:03 PM   #9
Yooper truck
Try needle nose pliers first to pull it out. If that doesn't work, use a small drill bit and drill just far enough so the threads start to grab and put in a small screw just far enough so the threads will grab.
By the way I found out that these are not remanufactured. There is a different part they are substituting for it. I was fortunate and found a NOS part on a suburban being parted out last fall.
Old 03-21-2012, 08:07 PM   #10
davepl
davepl's Avatar
It's a long-shot, but if you had a defective bulb couldn't it short from the park to brake circuits within the bulb? Then, whenever you hit the brakes, power would leak from the brake light to the entire park light circuit.
I think if that happened when you hit the brakes the side marker lights would come on as well.
I realize the hazard is pretty much the confirmed issue, just throwing it out there in case anyone has a similar problem in future and stumbles across this thread.
davepl is offline   Reply With Quote
Old 03-21-2012, 08:18 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If the hazard warning light circuit is intact and working correctly, engaging the brake light switch will make all turn signal bulbs light steadily. Otherwise, engaging the hazard switch in a normal circuit, would make them flash...all four of them.
So, you may also have a bad/missing hazard flasher.
But, a 42-year old vehicle can't be depended upon to not have wiring/electrical and/or component issues.
Member Nr. 2770
Old 03-21-2012, 08:33 PM   #12
This way the people in front of you know when you're braking. That's parking lamps,not fog lamps.
You can pull the button out. To fix it you need to pull the wheel and put a new canceller in
Old 03-22-2012, 11:47 PM   #13
rener57
Guys I'm very grateful for your advice. It was right on.
The hazard flasher was missing on the fusebox. Once I plugged in a flasher the lights started flashing. The red button above was indeed stuck. I was able to pull it out with pliers afterwhich my turn signals started working again.
For the short term I did drill a hole in that broken hazard button and screw in a screw. End result I can easily use my hazards if needed. Thanks again everyone!
Here is a pic
Old 03-22-2012, 11:53 PM   #14
MikeyMan
Nice job on the hazard knob! I had the same thing on a 70 GMC.
MikeyMan is offline   Reply With Quote
Old 03-23-2012, 08:57 AM   #15
Get a cabinet knob at the hardware store and give it style! Gad you figured that out.
Old 03-23-2012, 10:01 AM   #16
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
That's why I love this site. The guys here are great.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
