Old 11-23-2011, 10:05 PM   #1
RivRat
54 grill on pre 54 ADs
what is needed to change the front end on my 1950 to have the 1954 grill.
would it just be the fenders and grill or does the hood have to be changed too.
i have always loved those grills but never liked the one piece window. Would there be a way to change the grill by just cutting the 1950 fenders. i have a great patina going and would hate to lose it.
RivRat is offline   Reply With Quote
Old 11-23-2011, 10:32 PM   #2
RivRat
Re: 54 grill on pre 54 ADs
Old 11-23-2011, 11:03 PM   #3
solidaxel
solidaxel's Avatar
WOW, that was faster than T V time !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-23-2011, 11:19 PM   #4
RivRat
what do you think
Old 11-23-2011, 11:34 PM   #5
solidaxel
solidaxel's Avatar
Chrome the 53 grille
LS 3 4L70E
Old 11-24-2011, 01:57 AM   #6
jocko
jocko's Avatar
im a 54-55 grille fan personally - but your current grille matches your truck so well, I don't think I'd change a thing. I'm FAR from an expert on these, but I THINK the only mod you need to do is 54-55-specific front fenders to swap to the newer grille. I am not sure if earlier fenders could be modified to work - at a minimum, you'd need to make holes for the wiring/parking light lenses, etc - which is certainly doable, but not sure if you would have a proper fit in that area of the grille. I just don't know.
Old 11-24-2011, 02:34 AM   #7
meter swinger
meter swinger's Avatar
Goddang man that is sweeeeet. But ive always loved the 54/55.1 mouth. Do it that looks awesome.
meter swinger is offline   Reply With Quote
Old 11-24-2011, 10:21 AM   #8
sweet70beast
sweet70beast's Avatar
You will need to switch the fenders too. If you look at the picture with the 54 grill on it you can see the 53 grill in the upper corners above the 54 grill. On 47 to 53 fenders this area is square and on 54-55.1 fenders this area is rounded. Another option is that you could weld a piece of metal in that spot to round it, since it is such a small area. Another problem with the fenders is that on the 54-55.1 grills have the park lights below the headlights and behind where these go the fender is recessed to accept these lights. It could be made to work if you wanted to cut a hole in your fenders. The hoods are the same. I wanted to do the opposite on my 54 Suburban, I wanted to use the older grill so I did a lot of checking with the parts that I have and discovered this about the fenders. It can be done but it will take some work.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 11-25-2011, 11:59 AM   #9
Rudoo
I am new here and your post caught my eye because I just bought a 54. I looooooove your truck!!! It is exactly the look I want. I am new to trucks, so I may ask dumb questions. Did you do the paint job?
Rudoo is offline   Reply With Quote
Old 11-26-2011, 05:41 PM   #10
RivRat
no that's natural patina. i was told it sat in a field for 20 years before it was built.
Old 11-27-2011, 10:00 AM   #11
Dan Bowles
AD Addict
There are some differences on the inner fender wells on the '54s as well. Hood isn't a problem. It is only an emblem mounting scheme change that I can see. I do have someone trying to convince me otherwise but I don't believe it.
I would love to have a chrome '54-55S1 grille for my truck but haven't found a good one yet that isn't an arm and a leg. I think they look better with the one piece glass, though. My personal preference. I was raised on the '54s.
Dan Bowles is offline   Reply With Quote
Old 11-27-2011, 02:37 PM   #12
54foster
I wouldn't touch that truck! I am currently starting a build project on a 54 and there are a few differences, the hood is fine however both the fenders and the inner fenders are different. So to make it work you would have to change the front fenders or cut and piece together fenders. And I think it would take away from the look of the patina on the truck.
54foster is offline   Reply With Quote
