11-23-2011, 10:17 PM | #1 |
Spray Paint Removal From SPID
Great site, learning alot about these great trucks. You can see my problem. 1970 CST with the SPID some what painted over with black spray paint. I would like to try and remove the paint without messing up the SPID. The SPID is not covered with plastic. Any suggestions??
11-23-2011, 10:31 PM | #2 |
Re: Spray Paint Removal From SPID
1) Keep that original glove box.
2) Have ChipFlyer make a new SPID. 3) Put the new SPID on a replacement glove box door. 4) Enjoy! |
11-23-2011, 10:32 PM | #3 |
No hope for that one, get a new one made.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
11-23-2011, 10:36 PM | #4 |
Check out the link in Jeff's (chipflyer) signature. Do just like DANTIP says, get another door, save the old one, and put the repro SPID on the other door. Jeff's SPID's are amazingly accurate, the font is perfect. The font is not something you can simply replicate in word, it is a special font.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
11-23-2011, 10:44 PM | #5 |
My goal is to try and see what options it originally came with. I can make out some but not all. Will definitely put a new one on but need to know what to put on it.
11-23-2011, 11:57 PM | #6 |
Are you able to take some up close pics of the spid?
Bud |
11-24-2011, 12:14 AM | #7 |
Have this one but can take more if needed.
11-24-2011, 12:17 AM | #8 |
Would the ink from the options be visible from the back side if I removed the SPID?
11-24-2011, 12:20 AM | #9 |
Can you make out any rpo numbers or any of the descriptions? Can't see anything from that pic, doubt you would see anything if you removed it.
11-24-2011, 12:24 AM | #10 |
One more. Yes I have been able to make out about 9-10. Kind of piecing them together based on what I can see.
11-24-2011, 12:27 AM | #11 |
list what you can see
11-24-2011, 12:29 AM | #12 |
I'm thinking the following:
Option No. Description F51? HD Shock Absorber Equipment - Front & Rear F60? HD Front Springs 603 or 604? Black Vinyl Trim G50 HD Rear Springs M49 Turbo Hydra-matic U08 Dual Horns Z53 Ammeter, Oil Pressure & Temperature Guages Z84 Custom Sport truck ??? Black Door |
11-24-2011, 12:38 AM | #13 |
looks like truck was originally red? was it two tone? which column was the one you can't read in, left or right and is it the bottom one?
11-24-2011, 12:56 AM | #14 |
I think the truck was originally Orange. Was a LWB that got cut down to SWB. Kind of a hodge podge of things but I knew that going in. Can't really make out the RPO Codes in the left hand column. Can make out some in the right hand column but can't see much of the description. Ink is also faded really bad. Trying to piece together based on RPO Code list and what I can make out.
11-24-2011, 01:08 AM | #15 |
Maybe this?
f51 frt & rear shock abshhhhhf60 HD front springs g50 HD rear springhhhhhhhhhm49 turbo hydra-matic u08 dual hornshhhhhhhhhhjhz53 amp-oil-temp gauge z84 custom sport truckjjjjjjjjj565 orange/black 600 black vinyl trim
11-24-2011, 01:37 AM | #16 |
Chipflyer,
I appreciate your help on this. In looking at it closer I'm seeing the following: Option # Description ??? ???????? Engine ??? ???????? Doors?? ??? Rear Step Bumper EQ ??? Custom Sport Truck ??? Black Vinyl Trim G50 HD Rear Springs M49 Turbo Hydra-matic U08 Dual Horns Z53 Ammeter, Oil Pressure, Temperature ?65 Black ???????? You could be right on the 565 color combo. I can get the Option # based on the description but I just can't see it on the SPID. |
