11-23-2011, 11:14 PM | #1 |
Moderator
New/Restored Tach dash for sale
Here is a very nice gauge cluster that I restored. I used excellent OEM gauges, and repainted and clear-coated the needles. The tachometer is brand new, as well as new correct inner/outer tins, new lens, new chrome bezel, and a new circuit board. Pics speak for themselves. I will also include a new tach harness with this set-up. Bolt in and go. New tach clusters sell for $550+ from vendors, get a deal here.
$400 Shipped, tracked, and insured in the CONUS.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-23-2011, 11:15 PM | #2 |
Moderator
Re: New/Restored Tach dash for sale
pics
11-23-2011, 11:28 PM | #3 |
VA72C10
Nice work! All the gauges look good including the usually faded temp
Looking for a 67-72 swb or blazer project in or around VA. |
11-24-2011, 02:50 AM | #4 |
Just a Member
WOW!!! I will be dealing with these bad mamma-jammas one day... GREAT WORK!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
11-24-2011, 02:34 PM | #5 |
Will that tach and harness work with hei ignition?
11-24-2011, 06:36 PM | #6 |
Moderator
Yes, it will work with hei...I have the same setup on my 402. The only thing you have to do is swap the horseshoe connector on the harness for a spade connector so it will plug into the hei cap...however if you are using hei with an external coil the horseshoe connector will work.
11-26-2011, 12:04 AM | #7 |
Moderator
Black Friday Bump. Open to reasonable offers...
11-28-2011, 09:22 PM | #8 |
Moderator
Sold to BBC Motorhead. Thanks Mike!
12-06-2011, 10:16 PM | #9 |
Got it tonight. It looks great! Thanks
