11-24-2011, 08:47 AM | #1 |
factory AC wiring question
I have a '71 with factory AC that had been taken apart by the PO.
I think I have most of it put back together with one exception. Under the dash,on the passenger side of the cab, I found two unattached wiring connections. One was a two wire connection that went to a switch driven off the AC cable and i found that one. There is another 3 wire connection that the schematic shows going to a resistor. I think the colors are green, pink, and yellow. Can anyone tell me where this resistor is, or should be, located? Posted via Mobile Device |
11-24-2011, 10:21 AM | #2 |
Restoration Virgin!
Re: factory AC wiring question
I believe it's the heater resistor....I got this from the LMC catalog...I think this is where it's located...inside the interior box...item#5...
http://www.lmctruck.com/icatalog/cb/full.aspx?page=119
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
