Old 11-24-2011, 08:13 PM   #1
Fan2zee
Fan2zee's Avatar
Wiper Delay?
After purchasing the 87', the wiper delay has never worked. I just replaced/installed a new control lever which operates the wipers/cruise..and the wiper delay still does not work. The wipers work on high and low speed.
I happen to look at LMC, and there is a diagram of wiper system and seen that there is a delay wiper module available.
I was wondering if it could be the wiper delay module?
Any input welcome!
87' R10
Fan2zee is offline   Reply With Quote
Old 11-24-2011, 11:53 PM   #2
john_p
Re: Wiper Delay?
yes, that is about the last possible bad spot
john_p is offline   Reply With Quote
Old 11-25-2011, 10:07 AM   #3
ges55
BLACK SATIN
ges55's Avatar
Re: Wiper Delay?
I picked up an 85 not too long ago & had the same problem, except mine was intermittent. I picked up a module on Ebay for $25 & it works fine now. The module is located under the steering wheel behind the cover just below the steering shaft.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 11-26-2011, 12:24 AM   #4
Fan2zee
Fan2zee's Avatar
Re: Wiper Delay?
Yep, I'll give it a try.
87' R10
Old 12-01-2011, 10:22 PM   #5
Fan2zee
Fan2zee's Avatar
Re: Wiper Delay?
Just installed new wiper delay module. Didn't work out entirely. Now when I turn the switch to the delay the wipers move in a low speed but "no" delaying or intermediate. The wipers still work in Low & high speed. One more new problem, they will not turn off unless I switch to Mist mode.
Any suggestions? Bad module? Wrong module?
87' R10
