Old 04-20-2003, 11:39 AM   #1
69Chevyc10
1988 Chevy 4X4 front differential won't lock up !!
I have a 1988 Chevy 4X4 and the front differential won't lock up.
The transfer case shifts into 4 hi and 4 lo fine its just that the auto hubs wont lock the driveshafts up front. The front driveshaft spins, just no power transfered to the wheels, it just free spins.
any suggestions would be appreciated.
69Chevyc10 is offline   Reply With Quote
Old 04-20-2003, 02:02 PM   #2
sakohntr
sakohntr's Avatar
front
If you have the front independant suspension, more than likely your thermal actuator is bad. This is common. You can verify this by checking to see if you have voltage going to the front dif where this actuator screws into the side of the pumpkin. There is also an aftermarket version available that is manual, whereby you pull a cable that slides a plunger which replaces the original electric actuator. It is called posi-lok. The 88-93's were slow in engaging. They then went to a hi speed actuator after that. good luck
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
