Old 11-25-2011, 08:28 AM   #1
big d's red67
big d's red67's Avatar
Disc Brake conversion question
I have searched for this and can't find an answer, I have power drum brakes on my 67 when I switch over to disc's do I need to change the brake lines from the prop valve that run down to the frame?
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 11-25-2011, 09:46 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc Brake conversion question
Yes.
Your drum brake truck has a distirbution block.
(not a proportioning valve)
You will need a disc brake proportioning valve and the steel lines will be different.
Keith
Convert to disc brakes.
Old 11-25-2011, 10:38 AM   #3
cdowns
cdowns's Avatar
master cylinder is different too// the rear brake line may be the same but not fronts
Old 11-25-2011, 10:48 AM   #4
big d's red67
Do I need to replace all of the front hard lines ?
Old 12-24-2011, 01:18 AM   #5
LowGT
LowGT's Avatar
I'm curious about this as well. I just finished everything for my disc/drum conversion and was disappointed when I figured out the fittings on the distribution block are different from the prop. valve.
Are there different year hard lines that can be used? Can I just use adapters? Do I need to bend/flare my own? Anyone know what size tube/fitting is needed?
65 SWB BBW - 283, TH400
LowGT is offline   Reply With Quote
