11-25-2011, 05:07 PM | #1 |
~Craig~
Stock Pump To Q-Jet Fuel Line Replacement ?
Hi guys, I've been trying to tune my carb, and realized that I've been leaking at the pump outlet for quite some time. I think I over tightened the line when I replaced the pump. I cant seem to find what size the connectors are, and I cant find many solutions at local part stores, even went to the jy today and couldnt find a line everyone had been pulled already! What would you suggest? I know rubber is a fire hazard so i'm going to stay away from that route. How tight should I tighten the line at the pump and carb?
Thanks so much Happy T-day weekend |
11-25-2011, 05:32 PM | #2 |
Re: Stock Pump To Q-Jet Fuel Line Replacement ?
they sell the line pre bent on LMC I believe. I need to order one too as my PO ran a rubber line
1967custom |
11-25-2011, 05:57 PM | #3 |
All the vendors, or most sell that line.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-25-2011, 06:29 PM | #4 |
any autoparts store should have it but it won't be prebent you'll have to bend it yourself its just 3/8 fuel line
