72 Drum Brake Question
Hey guys,
I have a 72 c-10 that i did a 6.5 diesel swap. The motor is running and everything is working great except the driver side rear drum. When I press on the brake pedal the shoes seem to unseat and will not release, so they sit there and drag on the hub. Does anyone have a clue why this is happening? I have inspected everything and it seems to be in good order. Also this has a hydro boost system on it. Thanks everyone! ![]()
![]() ![]() 2000 Ford Powerstroke (daily driver) |
#2 | |
Active Member
![]() Join Date: Jul 2007
Re: 72 Drum Brake Question
Happened to me about 15 yrs ago. The hose swells internally allowing fluid under pressure to expand the brake shoes but the spring tension is not enough to allow it to retract because of the restricted flow on the rubber hose. |
