Old 11-26-2011, 05:57 PM   #1
DBear
DBear's Avatar
67-68 Grille Hoops
does anyone know what the original hoops were made out of? Is it the same that the new aftermarket are made of? I know the originals are fairly heavy and thick. Thanks guys
DBear is offline   Reply With Quote
Old 11-26-2011, 07:53 PM   #2
oldspowered67C10
Re: 67-68 Grille Hoops
Just stuck a magnet to my OEM ones and it stuck so I'm saying steel. Didn't stick to my aftermarket ones.
oldspowered67C10 is offline   Reply With Quote
Old 11-26-2011, 08:17 PM   #3
Hutch
Hutch's Avatar
oldspowered67C10
There are two different types
One appears chrome and the other is painted from the factory
The factory painted ones can be chromed and the others will need to be replaced\restored.
Other folks will chime in an verify this
A lot of folks want the factory painted ones to strip and chrome for a better look
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 11-26-2011, 09:42 PM   #4
Livrat
Member #1049
Livrat's Avatar
From the factory there were two types,
The shiney ones were aluminum, the painted one were steel. All of the aftermarket ones I have seen are aluminum.
My favorite thing to do is use the painted steel ones and have them chrome plated.
Livrat is offline   Reply With Quote
Old 11-27-2011, 11:50 AM   #5
Sammy
What would a guy expect to be charged to have a set chromed? How did they come out? Just curious trying to compare a set being powdercoated while I decide.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-27-2011, 12:08 PM   #6
Livrat
Member #1049
Livrat's Avatar
Chrome plating has gone way up since I did my last ones, I would guess some where in the neighborhood of $150-$175 each
I recently did have a pair powdercoated in "near chrome" and did not like it. I was told by my powdercoated that the problem is the near chrome itself looks good but it does not have any UV protection so if it going to be out in the weather they have to clear coat over the top and it turns out looking just like anodized aluminum
Old 11-27-2011, 12:24 PM   #7
msgross
msgross's Avatar
I thought about having a set chromed, then found out the cost...
Ended up picking up a set of NOS aluminums for $160 or so... they come up every once in awhile.
The aftermarket one's are cheap and flimsy but will do the job for most guys.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-27-2011, 12:29 PM   #8
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I'm having my painted steel hoops powdercoated.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-27-2011, 01:03 PM   #9
mbgmike
Here is a picture of the cheap and flimsy ones on a members truck. They actually fit real good
mbgmike is offline   Reply With Quote
Old 11-27-2011, 01:27 PM   #10
mbgmike
check out this post
http://67-72chevytrucks.com/vboard/s...d.php?t=495482
we are going to send them some stuff and see how it works. Looks a lot less than anything around Houston area
