Old 11-27-2011, 04:04 AM   #1
67L30WGN
67L30WGN's Avatar
Oil Pressure Switch for Guage & Electric Choke
Although it would only require a simple oil pressure switch over the fuel pump, I'd like to avoid running long wires all the way from under the dash to the front of the engine and than back up to the choke.
If possible, I want to switch my electric choke on/off only when the engine is running through a single oil pressure switch located at the back of my block, but the switch must also double as a mechanical guage (oil tube) fitting, not an idiot light sending unit. Wondering if anyone knows of such a part? Not sure if I could find a tee to fit both, but open to it.
1972 Cheyenne Super 10 LWB
1965 Nova SS Evening Orchid
1967 Nova Wagon Factory Disc (1 of 565), 327/PG
1964 Ford Fairlane 500 HT
1962 Nash Metropolitan Convertible (Wife's car)
67L30WGN is offline   Reply With Quote
Old 11-27-2011, 05:02 AM   #2
67L30WGN
67L30WGN's Avatar
Re: Oil Pressure Switch for Guage & Electric Choke
Correction: I meant I didn't want to run down by the oil filter and back up (not front of engine). I'm referring to the second oil pressure pickup location in the block above the oil filter.
electric choke, oil sending unit, wiring
