![]() Join Date: Jan 2010
WTB 1piece drive shaft 4x4
Finishing up changing over from a t221 to np201 and it's tiMe to find a drv shaft. The axle is a 1/2 ton 72 and need the drive shaft to fit np205 - 72 axles.
Thanks, Don Posted via Mobile Device |
Newbee
Re: WTB 1piece drive shaft 4x4
Measure your yokes, and take a center to center measurement. Any good driveshaft shop can make one up for you.
![]() Join Date: May 2009
may have a driveshaft send me center to center measurements and i will double check for you
Can't get measurements right now as the trans is on my work bench getting a rebuild. A stock 70-72 should fit as I am changing out the tc to a 205 and the axles are 72's.
I have a complete driveshaft that is 50 inches from u joint to u joint
Great, thank you. I will be done with my trans rebuild this week and hopefully have it installed this weekend. I will get the measurements. What would you be asking plus shipping to 08527 NJ?
