SSN 706
lokar shifter cable or linkage?
I need to buy a Lokar shifter for my 52. I want to keep the bench seat. What I need to know is if I need to buy the cable type shifter of the linkage type?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 11-27-2011 at 12:22 PM. |
Re: lokar shifter cable or linkage?
Use the linkage. and buy it from summit, save a little money..
SSN 706
Thanks guys I was kinda worried that the linkage set up might not fit, but from the looks of it, it should work fine.
I made my cable one using B&M and off the shelf parts, much cheaper than the kits.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
I used the cable from a b&m shifter too
Cruzin
hard linkage, works much better in my op.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Am runnin; a 700R4 - aint got no linkage
If you can look for one that mounts to the cab floor. I have the trans mount one and have had some issues. Mounted on the trans it thansfers all driveline vibration to the shifter, the longer the shifter the more shaking. The linkage did not adjust per Lokar, when in park I could not get 1st gear. When setting up adj in netural the detents on the shifter did not match the trans detents to MY likeing. This was fixed by making a longer lever(about 3/4")on the trans side. I cut the hole in the floor as small as I could for the shifter but I still was getting heat from the exhaust and underside comming up thru the floor.
SSN 706
I was kinda worried about the shaking issue. Maybe a boot to fix the hole/heat thing.
jjjmm56, get some fire safing insulation (it is denser than standard fiberglas and fireproof) and stuff it around the shifter inside the console. fab a closure out of black plastic with a hole the diameter of the shifter and sized to keep the oblong slot covered in all shift positions. Use a wire tie under the black piece to keep it snug against the console bottom. same with the insulation around the shifter in the console. That should help with heat and fumes.
Or fab a boot for the top and fill it with insulation (my solution for my transfer case shifters and the previous floor tranny shifter I had.).
Cruzin
i installed a floor mount in my wife's 67 no shaking, also used there hard linkage was a snap to install. I have a boot but haven't installed it yet waiting on carpet.
#13 |
#14 |
SSN 706
Ok, so Im going with the linkage. 32 double bend with the boot. Thanks for all the pictures guys.
#15 |
get it from american shifter co.
knock off of lokar and way cheaper. both are so chinese so whats it matter? |
#16 |
Not to argue here been to Lokar shop many times in TN and they make all there in parts in house at there shop even there shifters we are talking about.I feel you should buy from a vendor on this site.We have some great prices on lokar products and they have customer great service.
#17 |
#18 | |
Cruzin
#19 |
Lokar products are all made in the USA. Lokar gives tours anytime. We carry a lifetime warranty on all our products. Please anytime you are in the east Tennessee area stop by we will be happy to give a shop tour. You will clearly see that we manufacture our products in the USA. We also suggest that you shop with one of our many dealers. If anyone has questions or needs part numbers please call and we can get you what you need so that you can get the product that is right for your application. Toll Free1-877-469-7440
#20 |
well there ya go. thanks for keeping me straight.
#21 |
SSN 706
Think I'll get it from Scottshotrods. Justin usally gives me a good deal.
#22 |
IMHO, the 32 is too long. Had the 32" in mine and it shook and was wobbly. Not a mechanical issue nor a slam on Lokar. I bought the Lokar 16" double bend and installed it, no shake and solid through the gears. It's just simple physics, the further the handle is from the fulcrum, the more the movement is amplified. I love the shifter in the shorter version.
#23 |
I have a trans mount 23 inch Gennie Shifter for my 350 turbo in my Model A and after riding in my friends truck with a Lokar cable shifter I wish I had one.
#24 |
I have used both the Lokar rod type shifter and the B&M cable shifter.
Both grate shifters The B&M shifter came with a small consal and gear indicator (put this in a 88 Ford Ranger v8 auto prodject with flat floor.) Came with every thing to install including the shifter levers that bolt to the trans. since I was useing it with auto 4 Ford I had to get a supplemntery kit that replaced the shaft that trans lever bolted to. The lokar I used on a 74 nova that was auto consol car with floor mounted shifter. was easy to instal per instuctions. did not come with gear indidator, that is a sepert kit. only 2 problems I had was 1 I wanted to use my consol to cover the holes in my new carpet,can not find a ruber boot to cover shifter / hole (used the hole that was in floor from factory) 2 when ordering one of these the length is not from the floor mounting to the top of the knob but rather starts at the top of the shifter. The factory shifter mounted under the floor with just the lever above the foor so I ended up afew inches longer than I wanted. there is a boot kit for it , but it is a sewed vinyl with crome ring. ![]()
http://www.cardomain.com/id/jmcleek |
#25 |
SSN 706
